Audi RS 6: Resetting Automatic Transmission Learning Values
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
milledriver
Post05-08-2014, 18:04    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Hello everyone.
I would like to reset the adaptation values of the automatic transmission control unit.
"Where exactly can I find this function in VCDS?"
This is a 2002 Audi RS6.
Thank you for your help.
Translated on 01-08-2026, 1:45.
Post05-08-2014, 19:08    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Please perform an automatic scan (the Vehicle Identification Number may be missing).
milledriver
Post06-08-2014, 20:41    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Vielen Dank für die Antwort. Here's the car scan:
Best regards, Dani.
Log-WUAZZZ4B23N900826-158390km-RS6.txt
 File name:  Log-WUAZZZ4B23N900826-158390km-RS6.txt
 File size:  5.76 KB
 Downloaded:  793 times
Translated on 01-08-2026, 1:46.
Post06-08-2014, 22:36    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Hello Dani,
Unfortunately, I couldn't find anything about that in the "The 01V and 01L Automatic Transmissions pdf," but it might be helpful for repairs.
Perhaps a transmission specialist might know more about it.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post08-08-2014, 19:33    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Hello.
It is a transmission with automatic gear selection (ZF) and adaptive transmission control (AGS).
a brief explanation about the topic icon_exclaim.gif.
The Adaptive Gear System (AGS) calculates the optimal gear selection for vehicles with automatic transmissions, taking into account a wide range of factors.
It takes into account the individual driving style and the specific driving situation. The AGS recognizes the individual driving style based on the position and movement of the accelerator pedal, the deceleration during braking, and the lateral acceleration when cornering.
Due to different switching characteristics:
- from comfort to performance-oriented.
The AGS selects an appropriate setting. To take driving conditions into account, the AGS registers curves, inclines, and downhill sections.
When driving through fast curves, for example, it doesn't upshift. On inclines, it only shifts to a higher gear at higher RPMs in order to better utilize the power reserves.
On flat roads, the AGS disengages when the vehicle accelerates and the driver applies the brakes.
The control system will enter basic mode if the power supply is interrupted for an extended period.
What doesn't really make sense icon_wink.gif in everyday operation.
Here's how it's done:
- Engage the handbrake.
- Turn the ignition on, but the engine won't start!
- Press the foot brake and shift the gear selector to "D" (Drive).
- Release the foot brake.
- Now press the accelerator pedal all the way down, including using the kickdown function; that's important.
- maintain this position for more than one minute.
- then skip it and turn off the ignition.
- ready
Then just start driving normally again. Give it a try, it works great.
Regards, Mpire.
Translated on 01-08-2026, 1:49.
mullemaus
Post08-08-2014, 21:37    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Give it a try; it's wonderful.
Translated on 01-08-2026, 1:52.
milledriver
Post23-08-2014, 16:43    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
It worked, thank you.
Translated on 01-08-2026, 1:53.
Post23-08-2014, 17:21    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Hello.
How did you know that it worked?
milledriver
Post24-08-2014, 12:21    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
After the automatic transmission overhaul, it was shifting harshly when going into second gear.
It's gone now.
Post24-08-2014, 13:18    Subject: Audi RS 6: Resetting Automatic Transmission Learning Values Quote
Well, but how do you know if it was just the normal adjustment process from the control unit or something caused by those strange button presses?
To be honest, I think that instead of the steps mentioned above, you might as well just pick your nose – the chances of success are likely to be the same.
In one of the measurement blocks from the automatic control unit (012,2, Dynamic Index), you can see how the driving dynamics program is performing; this could reveal whether the procedure has any effect or not. icon_idea.gif
Translated on 01-08-2026, 1:54.
No new posts Reset Learning Rates: Null Set Correction On-Board Diagnostics (OBD)
No new posts Service Reset/Disable Beep Transmission, Chassis, Body & Interior
No new posts VCDS V158 Learning Values - HELP Transmission, Chassis, Body & Interior
No new posts Reset WIV: Incorrect Infotainment Values On-Board Diagnostics (OBD)
