WARNING: RUST IN FRONT WHEEL ARCHES, GOLF III, 1995
markuskxy
Post21-09-2003, 21:19    Subject: WARNING: RUST IN FRONT WHEEL ARCHES, GOLF III, 1995 Quote
HELLO
Recently, I discovered that a large amount of damp dirt (earth, sand, and various leaves) had accumulated in the area near the door, after removing the plastic cover in the front wheel well.
BELOW, RUST ERODED THE METAL!
I JUST WANTED TO WARN YOU!
After 5-8 years, it's a good idea to take a closer look.
OF COURSE, EVERY THIRD GOLF ALSO RUSTS AT THE REAR DOOR (ABOVE THE LICENSE PLATE)!
Also, please also check under the door seal (lower area), you will find rust there!
Best regards.
MARKUS
Nuckelpinne_72
Post21-09-2003, 21:34    Subject: caps lock Quote
Hey Markus;
Marcus.
LZ
Post22-09-2003, 20:41    Subject: WARNING: RUST IN FRONT WHEEL ARCHES, GOLF III, 1995 Quote
Unfortunately, there's nothing new:-(. It's coming from the water drainage system under the windshield wiper cover. Every leaf that gets stuck in there can't get out from the bottom. Sand and grime make it even worse. Last week, I removed the fenders and discovered the scenario I described. In my opinion, the only measure that needs to be taken is to occasionally remove the splash guards after each winter to check for any issues.
best regards, robert.
Post23-09-2003, 7:36    Subject: WARNING: RUST IN FRONT WHEEL ARCHES, GOLF III, 1995 Quote
It's the same with my A3 from 7/98. icon_sad.gif You just have to remove the inner fender liners every couple of years.
Tagessuppe
Karma: +38 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post23-09-2003, 11:58    Subject: WARNING: RUST IN FRONT WHEEL ARCHES, GOLF III, 1995 Quote
Rust on a three-iron golf club?
No new posts VW Golf PD, 150 hp, first registration 03/01 Diesel Engine Technology
No new posts Boost Gauge for VW Golf IV TDI PD 100 Diesel Engine Technology
No new posts Golf TDI PD: Fuel Consumption Data Diesel Engine Technology
No new posts GOLF 3 Brake Drum ABS Transmission, Chassis, Body & Interior
