Status LEDs on the VCDS interface and their colors
Post13-04-2015, 16:58    Subject: Status LEDs on the VCDS interface and their colors Quote
The manual only states that the LED should light up green after 2 seconds, and if it lights up red, there is an error in the connection or wiring.
Today I had a problem where the LED light was orange and no connection could be established. What does this indicate?
Translated on 13-07-2026, 11:34.
Post13-04-2015, 17:23    Subject: Status LEDs on the VCDS interface and their colors Quote
Click the "Connection Test" button in the VCDS program settings, and the dialog box that appears will then tell you what the problem is.
CAN can only be "ready" if it is also connected to the diagnostic connector. This is not the case for all models.
In the case of an error with the K-Line signals, it will explicitly state "short circuit to ground" or "... positive."
 VCDS Anschlusstest in den Programmeinstellungen
 File size:  80.19 KB
 Viewed:  3712 times
Translated on 13-07-2026, 11:35.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS Interface for 24V systems On-Board Diagnostics (OBD)
No new posts Announcements: VCDS-Mobile®, HEX-NET® Interface On-Board Diagnostics (OBD)
No new posts VCDS Interface Hardware: Different Versions? On-Board Diagnostics (OBD)
No new posts BNSTGs and their light displays Electrical Systems, Vehicle Electronics, Multimedia
