While exploring what all the long coding sequences offer, I came across the setting "Multi-link rear axle" in the LWR-StG (likely referring to a control unit) of my Polo. Of course, this is incorrect, because it actually has a semi-trailing arm rear axle, which is even conveniently listed in the dropdown selection.
So, I correctly re-encoded the stability control system, but in doing so, I introduced an error that cannot be erased â even after reverting back to the multi-link rear axle configuration.
The STG scan now looks like this:
Code: |
Mittwoch,02,September,2015,17:25:39:64765
VCDS -- Windows-basierter VAG/VAS-Emulator LĂ€uft mit Windows XP x86
VCDS Version: RKS 15.7.0.0
Datenstand: 20150818
Adresse 55: Leuchtweitenreg. (J431) Labeldatei: DRV\6R0-907-357.clb
Teilenummer SW: 6R0 907 357 HW: 6R0 907 357
Bauteil: LWR-ECU H02 0070
Revision: -------- Seriennummer: --------------
Codierung: 0112000001000000
Betriebsnr.: WSC 00788 648 00255
ASAM Datensatz: EV_HeadlRegulVWLWRPt 001004
ROD: n.v.
VCID: 77F63D68CE31B98666-8022
Keine ASAM Daten verfĂŒgbar: "EV_HeadlRegulVWLWRPt" (VW26)
1 Fehler gefunden:
5275220 - ROD - Unbekannter Fehlercode
- 00 [137]
Warnleuchte EIN - bestĂ€tigt - geprĂŒft seit letzter Löschung
Umgebungsbedingungen:
Fehlerstatus: 00000001
FehlerprioritÀt: 1
FehlerhÀufigkeit: 1
VerlernzÀhler: 133
Kilometerstand: 3698 km
Datum: 2015.09.02
Zeit: 17:19:24 |
"Before:"
Code: |
ROD: n.v.
Kein(e) Fehlercode(s) gefunden. |
By the way, the technically correct coding for a multi-link axle was 0102000001000000.
The command to delete the FS (file system) is accepted, but the same text reappears immediately. Turning the ignition off - waiting for about 1 minute - and then turning the ignition back on does not help.
Can I at least hope that the error will be automatically cleared after 133 trips (see above, mileage counter)? Today, after the action, there were no more trips pending.
