Unable to save after update
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
poppel
Karma: +1 / -2   Thank you, like it!
Post13-09-2015, 17:42    Subject: Unable to save after update Quote
Hello, after the update, I can see the status of the interface after the initial start and press the "Save" button, but the status is not being saved. I then have to go back to Settings - Connection Test - Save, and then start all over again. The status is not being saved even though everything is being recognized correctly. I have also tried uninstalling everything and completely re-downloading and reinstalling it. The same mistake, every time.
"Need Help."
Best regards, Thorsten.
Post13-09-2015, 17:48    Subject: Unable to save after update Quote
Was the VCDS installation folder modified from the default location? It sounds like there might be missing or incorrect user permissions when saving.
poppel
Post13-09-2015, 20:28    Subject: Do not save Quote
Hello, no, the folder has not been modified. The user permissions are the same as always. There is only one user on the computer, and that user has administrator rights. Windows XP Professional.
I have now uninstalled and manually deleted all the folders. Then I restarted and reinstalled. The same problem persists. "Press Save" does not work. It is not being saved.
Thorsten.
Post13-09-2015, 20:45    Subject: Unable to save after update Quote
Diagnostic cable not connected to the car?
poppel
Post13-09-2015, 21:53    Subject: Unable to save after update Quote
"You're right, the diagnostic cable isn't connected. Should it be plugged into the car?"
Thorsten.
Post13-09-2015, 22:43    Subject: Unable to save after update Quote
Yes, it's no longer possible without it.
I think it's been like that since the fourth-to-last version; before that, it always worked without the car.
poppel
Post13-09-2015, 22:51    Subject: Unable to save after update Quote
Okay, I will test that tomorrow.
Thorsten.
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts VAG 2.0 TDI mit Ausgleichswellenmodul, kein Öldruck Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts ASV Error: 'Engine Speed Sensor G80 - No Signal' Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Nach Update Fehler p1640 On-Board Diagnostics (OBD)
No new posts No Connection to Control Unit After Update On-Board Diagnostics (OBD)
No new posts Softwarestand MSG 038 906 019 AQ, Update möglich? On-Board Diagnostics (OBD)
No new posts 1.6 CR TDI: High Fuel Consumption, Software Update? Diesel Engine Technology
