Audi A6/4G MMI Plus Hidden Menü freischalten | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Karma: +1349 / -0   Thank you, like it!
Post12-08-2015, 4:08    Subject: Quote
You have the channel, right? Can't you just switch it between on and off?
Translated on 16-08-2026, 18:29.
Post13-08-2015, 9:21    Subject: Translating...
[Translating...]
Post19-08-2015, 21:23    Subject: Quote
So, have you tested it yet?
pitflick62
Karma: +0 / -1   Thank you, like it!
Post20-08-2015, 0:27    Subject: Quote
Hello Rainer,
Unfortunately, I don't understand what you mean by that.
dieselschrauber wrote:
"That's what I meant to say. And no, I haven't tested anything yet, because I also have to work sometimes, and I just read your posts."
Unfortunately, I won't be able to test anything before the weekend, if you're referring to Herbert's post.
Jörg.
Translated on 16-08-2026, 18:30.
dieselschrauber likes this.
Post20-08-2015, 9:27    Subject: Quote
Geh mal von der Leitung runter. Du hast in einem andern Portal eine Anleitung gefunden, die nicht mehr ganz zum A6 4G Facelift MMI passt. Das hast Du zwar gemerkt, aber jetzt erwartest Du scheinbar, das VCDS bzw. das Forum hier Dir erklärt, weshalb Audi für das was Du tun möchtest, nicht mehr den Adaptionskanal 6 bereit hält. Die Herren Entwickler geruhten halt, den Kanal jetzt woanders hinzulegen. Das VCDS zeigt sogar den vermutlich entsprechenden Adaptionskanal "Entwicklermodus" anwählbar, sh. Dein [Image of a Screenshot]
If you want to change the setting in the "Developer Mode" channel and are sure about what you're doing, then go ahead. Whether this unlocks a hidden menu is something you'll have to figure out yourself. Neither VCDS nor this forum are responsible for that.
If the risk is too high for you, you have to wait until someone else figures it out for you.
You have had this information for three months.
Now you're coming back and asking annoying questions from the beginning again. Therefore, we would like to know if you yourself have done anything substantial and that you don't give us childish answers. The fact that you are not making progress is probably not due to the VCDS version being used.
Translated on 16-08-2026, 18:31.
Jackson
Post14-12-2015, 17:51    Subject: Quote
Are there any new updates regarding the developer mode?
I get a '4G FL' error message when I try to enable developer mode.
31 - Outside the scope.
Jackson.
Translated on 16-08-2026, 18:33.
No new posts Unlock/Enable the Audi A3's outside temperature display Troubleshooting & Guides
This topic is locked, you cannot edit or reply. Towing Hitch Unlock: VW Golf 5 and Newer Models Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts {SOUND_TYPE}: Rumble {VEHICLE_MODEL}: Audi A3 8P Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Activate AHK on Audi A4 B8 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Unlock TV on Audi A8: Easy Guide Transmission, Chassis, Body & Interior
No new posts Audi A6: Unlock Immobilizer with Code via OBC On-Board Diagnostics (OBD)
No new posts Hidden MFA Menu: How to Access It Diesel Engine Technology
