Mercedes-Benz Vito, manufactured in 2012
Trautmann
Post12-01-2016, 14:02    Subject: Mercedes-Benz Vito, manufactured in 2012 Quote
Hello, is it possible to read a Vito using VCDS-Plus? With Autoscan, the system detects an error in the engine electronics and then stops.
Greetings.
J. Kämpf
Translated on 15-07-2026, 12:12.
Post12-01-2016, 14:32    Subject: Mercedes-Benz Vito, manufactured in 2012 Quote
Why don't you post the Autoscan?
It's possible that the Mercedes Vito uses shared control units with the VW LT/Sprinter (or at least a similar diagnostic protocol), and these might be accessible.
Translated on 15-07-2026, 12:13.
Post12-01-2016, 21:50    Subject: Mercedes-Benz Vito, manufactured in 2012 Quote
dieselschrauber wrote:
Possibly, the Mercedes Vito uses shared control units with the VW LT/Sprinter (or at least a similar diagnostic protocol), and these might be accessible.
Probably not; even with the LT, it was known that it used various control units from Mercedes, meaning that, for example, the airbag control unit could not be accessed using VCDS.
The LT incorporates many components from Mercedes, while the Sprinter does not contain any parts from Volkswagen. icon_wink.gif
Translated on 15-07-2026, 12:14.
Post14-01-2016, 16:11    Subject: Mercedes-Benz Vito, manufactured in 2012 Quote
While the various versions are still supported by VCDS, only the engine control unit and immobilizer can be accessed with VCDS on older LT models, while all control units can be accessed with VCDS on newer Crafter models.
The Crafter uses different control unit addresses than is typical for Volkswagen. Has anyone tried to connect the current Sprinter using VCDS yet?
Translated on 15-07-2026, 12:15.
No new posts VW Sharan Mj.2011/2012 Software updates/Service measures Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter, Year 2012/2013, High Standby Current Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Fuel return line rubbing on VW Amarok, model years 2012-2014 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Mercedes Vito 10c: Parts for 1997/98 Models Diesel Engine Technology
No new posts Vito Partition: Alternatives & Options Transmission, Chassis, Body & Interior
No new posts Unlock Radio Vito: How to Do It? Transmission, Chassis, Body & Interior
No new posts Boost pressure control on the Vito V230 (pre-chamber engine) Diesel Engine Technology
