Umbau von AHD (102 PS) auf AUH (158 PS) beim LT35 sinnvoll? | Posts 16+
Go to page: Previous  1, 2
vwSchrauber
Post14-10-2016, 12:00    Subject: Quote
@Rainer:
However, the difference in engine displacement between the two engines, from 2.5 liters to 2.8 liters, isn't that significant, so the most important factor for a good engine lifespan will be proper engine cooling.
Remember that the AUH (or ATA, as it was called with mechanical injection) is a three-valve engine - and that's the only thing that makes it a desirable engine.
The engine code AHD doesn't tell me anything at first glance; I would need to compare them in detail.
Does the 75kW/102PS engine have a wastegate turbocharger? The turbocharger appears to be noticeably larger than the wastegate turbocharger on various 1.9 engines. I will send you a file to view via private message icon_wink.gif.
Translated on 06-10-2026, 15:51.
dieselschrauber likes this.
Post15-10-2016, 12:08    Subject: Quote
Tagessuppe wrote:
Are you not referring to the AXL? In my case, AHY and AXG are listed with 216 injectors.
Unfortunately, there is a lot of misinformation circulating, and especially eBay sellers generally lump AHY and AXG together. However, the parts catalogs from VW and Bosch speak a very different language on this matter.
AHY:
DHK VAG: 074130201K aka. Bosch 0432193669 = Injector set: 2437010060 = DSLA150P764 = 0.216mm
AXG:
DHK VAG: 074130201T also known as Bosch 0432193552 = Injector set: 2437010126 = DSLA150P1019 = 0.203mm
All 2.5 R5 TDI engines, without exception, use 11mm HD parts; the only differences exist in the valve lifters. icon_wink.gif
Translated on 06-10-2026, 15:53.
fouzek
Post17-10-2016, 12:32    Subject: Quote
TDI-GTI-4-Motion wrote:
All 2.5 R5 TDI engines, without exception, use 11mm HD parts. The only differences exist with the valve lifters. icon_wink.gif
Are you talking about the diameter of the distributor piston here? That is, for example, ACV-ESP and AHY/AXG-ESP all have the same distributor piston diameter, and only different cam profiles?
Here's what I don't understand: Why does using, for example, 216 injectors instead of 205 injectors result in more fuel reaching the cylinder with the same ESP (Electronic Spark Program), since the fuel delivery volume and camshaft profile/lift don't change?
Translated on 06-10-2026, 15:55.
Post17-10-2016, 12:50    Subject: Quote
fouzek wrote:
Here's the next thing I don't understand: Why does more fuel reach the cylinder with the same ESP (Electronic Spark Program) if I use, for example, 216 injectors instead of 205 injectors, since the fuel flow rate and camshaft profile/lift don't change...?
Because the fuel and the injection lines react "elastically" to the very high pressures that occur. icon_idea.gif
When you inflate a car tire from 1 bar to 2 bar, it doesn't become twice as large. Liquids, like gases, can be compressed, but to a much lesser extent. Nevertheless, even at the pressures used in typical fuel injections, these effects become noticeable. The VP37 injection pump has peak pressures of around 1200 bar, while current common-rail systems reach over 2000 bar. State-of-the-art systems (Bosch CRS3-25) achieve 2500 bar.
See also:
I'm sorry, but I cannot provide a translation without the text you would like me to translate. Please provide the text from the URL you mentioned, and I will be happy to translate it for you.
Translated on 06-10-2026, 15:57.
fouzek
Post17-10-2016, 13:28    Subject: Quote
Hutfahrer wrote:
- Doesn't the LT have rear-wheel drive, right? Is it possible to install a different rear axle?
- What is the engine speed at cruising speed? Is it high, very high, or rather not?
- Could a change in translation achieve a faster speed?
Something like that would then reduce sprint and climbing ability.
"First and foremost, I want more power. What you mentioned would be the next thing to consider. Currently, the motorhome reaches a maximum speed of about 120 km/h (approximately 75 mph) on the highway at around 3500 RPM. Ideally, through tuning, a different engine, and a different gear ratio (or, for example, the "trick" of using tires that are up to 8% larger), it would be great to achieve the same speed with lower engine RPM, which would result in lower fuel consumption."
Translated on 06-10-2026, 16:00.
Post17-10-2016, 22:48    Subject: Quote
Yes.
fouzek wrote:
That is, for example, ACV-ESP and AHY/AXG-ESP all have the same distributor piston diameter, but only different cam profiles?
Translated on 06-10-2026, 16:01.
Mpire
Avatar-Mpire
2019 Skoda Octavia
Post18-10-2016, 20:30    Subject: Quote
Here's a comparison image of two four-cylinder rotary engines as an example.
Regards, Mpire.
 File size:  94.34 KB
 Viewed:  2017 times
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt replacement on a 1.9L PD TDI Troubleshooting & Guides
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts TDI Afterglow: Necessary, Useful, or Myth? Diesel Engine Technology
No new posts WFS light fixture LT35 is burning Electrical Systems, Vehicle Electronics, Multimedia
No new posts LT35: Intermittent Acceleration Issues On-Board Diagnostics (OBD)
No new posts S2 Brake Conversion: Brake Hose Too Short? Transmission, Chassis, Body & Interior
