Please use the auto-scan function. Also, there isn't "the login" for a car; instead, there are numerous different logins for each control unit and for various functions.
12233 has nothing to do with the airbag control unit. Blindly trying different login codes is strongly discouraged if you don't know what each login code does within the respective control unit. It's not only pointless to try a login code for unlocking adaptation channels from the engine control unit on an airbag control unit; depending on the login code, it could result in a different configuration, unexpected functions, undesirable operating states, or malfunctions.
As a rule, there is a master switch in the glove compartment to deactivate the "airbag". But which one exactly?
VCDS usually displays the appropriate information when you hover the mouse cursor over the input field.
