DPF Replacement: Adjusting Ash Mass
Schmierpfote
Karma: +21 / -0   Thank you, like it!
Post27-02-2017, 1:31    Subject: DPF Replacement: Adjusting Ash Mass Quote
Hello forum, I replaced the DPF on my Touran (engine code BLS) and I can't reset the ash mass using VCDS. What am I doing wrong? I would be very grateful for a guide. I used Rainer's guide "Adjusting the ash mass or oil ash volume" as a template, but I haven't been able to get it to work. Best regards, Wolfgang.
Translated on 12-09-2026, 13:32.
Back to top Profile PM Email
Post27-02-2017, 6:53    Subject: DPF Replacement: Adjusting Ash Mass Quote
Then welcome, and for you as well:
1) Autoscan
2) Describe your problem.
If you reread your post critically, you (hopefully) will realize that, even with the best intentions, you don't seem to understand how to ask for help. What's not working? VCDS is giving the following message. Which channel are you unable to find? Please try to provide more details.
Translated on 12-09-2026, 13:33.
Post27-02-2017, 9:49    Subject: DPF Replacement: Adjusting Ash Mass Quote
... and for VCDS, please also provide a Screenshot of the screen where you adjust the ash mass or ash volume. Depending on the control unit, there may be slight differences. icon_idea.gif
Schmierpfote
Post27-02-2017, 18:35    Subject: DPF Replacement: Adjusting Ash Mass Quote
Hello forum, I've uploaded the Autoscan data and screenshots. Before removing the old DPF, I performed a regeneration while driving using VCDS.
The temperature rose to 870°C, but by shifting to a higher gear and reducing the engine speed, it dropped back down to 780°C. The DPF has discolored slightly on the outside, and it's light gray on the inside. I'll post some pictures. Thank you for your help. Best regards, Wolfgang.
 Beim Test war der alte Wert wieder da.
 File size:  2.26 MB
 Viewed:  1612 times
 Hier konnte ich nur bei "Neuer Wert" auf 0 setzen.
 File size:  2.26 MB
 Viewed:  738 times
Log-NM 18-296790km.txt
 File name:  Log-NM 18-296790km.txt
 File size:  4.37 KB
 Downloaded:  914 times
Log-NM 18-WVGZZZ1TZAW097744-296790km.txt
 File name:  Log-NM 18-WVGZZZ1TZAW097744-296790km.txt
 File size:  9.14 KB
 Downloaded:  534 times
Translated on 12-09-2026, 13:34.
Post27-02-2017, 19:53    Subject: DPF Replacement: Adjusting Ash Mass Quote
Yes, and? icon_eek.gif The forced regeneration doesn't empty the DPF, do you understand what you're doing?
Please provide the text you would like me to translate from German to English.
Translated on 12-09-2026, 13:35.
Schmierpfote
Post27-02-2017, 20:08    Subject: DPF Replacement: Adjusting Ash Mass Quote
Hello Rainer, I forced a regeneration on the old DPF, removed it, and installed a new one. Now I want to reset the ash mass to 0. I would like to clean the old DPF and reinstall it if necessary. Best regards, Wolfgang.
Translated on 12-09-2026, 13:36.
Post27-02-2017, 20:16    Subject: DPF Replacement: Adjusting Ash Mass Quote
Hello Wolfgang, okay, that's good. What does VCDS say if you first click "Test" and then "Apply" when the value is 0?
Schmierpfote
Post27-02-2017, 21:25    Subject: DPF Replacement: Adjusting Ash Mass Quote
Hello Rainer, everything is OK, icon_smile_thumb_up.gif on Sunday I tried to set the "ash value" for channel 12 to 0 in the engine control unit adaptation. It didn't work. You could only set 0 in the "New Value" field, and I also pressed "Test." "Apply" was not grayed out, perhaps because I closed the instruction (speech bubble).
A guide for resetting the ash mass after a DPF replacement, for someone like me icon_redface.gif who is a VCDS beginner, would be: Engine control unit, adaptation channel 12, delete the "new value" and enter 0, press "test", press "accept", and that's it.
This is definitely not a criticism, but rather an idea to make it easier for beginners, and it will give you more time for more important things. Perhaps, depending on the type of MSG installed, it may also need to be operated differently each time. Excellent forum. icon_smile_thumb_up.gif icon_smile_thumb_up.gif Thank you, Wolfgang.
 File size:  2.25 MB
 Viewed:  809 times
Translated on 12-09-2026, 13:37.
Post27-02-2017, 21:46    Subject: DPF Replacement: Adjusting Ash Mass Quote
Engine control unit, adjust channel 12, delete "new value", enter 0, press "test", press "apply", done.
Translated on 12-09-2026, 13:39.
No new posts Document startup issues, adjusting initial quantity Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VP44 Replacement: WFS Adjustment Not Possible (VW) Diesel Engine Technology
This topic is locked, you cannot edit or reply. VCDS: Adjusting Ash Mass for Optimal Performance Diesel Engine Technology
No new posts Warm Start Issues After MSG Swap 1Z to AFN On-Board Diagnostics (OBD)
No new posts Problems after turbo replacement Upload
