dennis91
Joined: 07/01/2017 Posts: 50 Karma: +10 / -0 Location: Igensdorf
17-07-2017, 18:33 Subject: LED Turn Signals & Taillights: Upgrade Guide |
Apparently, it's possible to convert the turn signals to LEDs because they can be recoded through the control unit.
Can someone explain how to code it using VCDS?
I would also like to disable the bulb monitoring for the reverse light.
How does the game work?
Translated on 20-08-2026, 22:22.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
17-07-2017, 20:01 Subject: LED Turn Signals & Taillights: Upgrade Guide |
Profile PM WWW Garage |
dennis91
18-07-2017, 16:52 Subject: LED Turn Signals & Taillights: Upgrade Guide |
dieselschrauber wrote: | | Which vehicle,Autoscan? |
Is this a Skoda Rapid Spaceback NH1 from the year 2016?
Translated on 20-08-2026, 22:23.
18-07-2017, 19:51 Subject: LED Turn Signals & Taillights: Upgrade Guide |
If you click on "Auto Scan," an explanation will also appear describing what it does.
dennis91
18-07-2017, 22:25 Subject: LED Turn Signals & Taillights: Upgrade Guide |
dieselschrauber wrote: | | If you click on Autoscan, it will also explain what it is used for... |
Okay, thank you  . I'll upload the Autoscan here in a few days.
Translated on 20-08-2026, 22:24.
dennis91
23-07-2017, 13:14 Subject: LED Turn Signals & Taillights: Upgrade Guide |
Here is the desired Autoscan  .
I hope this helps you.
| Description: |
 Download |
| File name: |
Log-FO-DG 710-TMBEA6NH1H4513072-11445km.txt |
| File size: |
10.15 KB |
| Downloaded: |
689 times |
dennis91 likes this. |
23-07-2017, 19:19 Subject: LED Turn Signals & Taillights: Upgrade Guide |
You can go through the individual bytes of the long coding sequence in the body control module (module address 09) and see if you can find anything related to the turn signals. Use the long coding assistant.
Translated on 20-08-2026, 22:25.
dennis91
24-07-2017, 12:30 Subject: LED Turn Signals & Taillights: Upgrade Guide |
Thank you! I'll take a look at it.
