Golf 7, 1.4 TSI CHPA
brezelmann01
Karma: +75 / -0   Thank you, like it!
Post21-04-2018, 8:43    Subject: Golf 7, 1.4 TSI CHPA Quote
Hi everyone,
I would like to replace the spark plugs on my Golf 7 1.4 TSI with engine code CHPA. It seems that a special tool is needed to remove the ignition coils. Is this correct? And if so, does anyone know the exact part number for this tool?
Pretzelman.
Translated on 12-07-2026, 16:27.
Post21-04-2018, 16:27    Subject: Golf 7, 1.4 TSI CHPA Quote
Hi there,
It might be the same as with the POLO 6R; for more details, check the parts catalog (RLF) or contact Etzold.
Translated on 12-07-2026, 16:28.
vag-driver
Post03-05-2018, 9:43    Subject: Golf 7, 1.4 TSI CHPA Quote
You probably should be able to manage with a set of pullers like a 4-piece puller set for ignition coils, suitable for VW Audi VAG vehicles.
Andreas
Translated on 12-07-2026, 16:29.
PetitPrince
dieselschrauber, brezelmann01 and Turbinchen likes this.
Post06-05-2018, 8:51    Subject: Golf 7, 1.4 TSI CHPA Quote
You won't have any luck with those pullers on this engine. The special tool required is called VW T10530. Check out "BGS 9073" on Google; it's similar but much cheaper.
Best regards, The Little Prince.
brezelmann01
Post06-05-2018, 17:53    Subject: Golf 7, 1.4 TSI CHPA Quote
Great! With the search term for the tool, I finally found a video. That's Kiki, so it should be doable even without special tools.
Thank you very much to everyone!
Pretzelman.
Translated on 12-07-2026, 16:30.
No new posts Golf 4 Fault Code Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf IV 1.9 TDI AXR - Stutters under load Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 5 1.4 BUD Misfire 2. Cylinder Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts 1.4 TSI CAX Idle Jerking/Surging Gasoline Engine Technology
No new posts Golf6 1.4 TSI 160PS - Timing chain elongation. VCDS Check Gasoline Engine Technology
No new posts Golf 3 Speedometer with Golf 4 6-speed? No signal. Diesel Engine Technology
No new posts Golf 2 GTD/16V: Brake Caliper & Wheel Bearing Mount Transmission, Chassis, Body & Interior
