Audi A6 4B V6 TDI: Overheating Issues?
willem4
Post12-05-2018, 22:28    Subject: Audi A6 4B V6 TDI: Overheating Issues? Quote
Hello everyone,
I'm having a problem with my Audi A6 4B V6 TDI, engine code BAU, manufactured in 2004.
Under load, such as when driving slightly uphill on the highway at approximately 140 km/h, the coolant temperature quickly rises above 90°. When driving downhill again, the situation eases. Sustained high-speed driving is also not possible. At the same time, the oil temperature is between 100 and 110° (which is within the normal range).
Recently, I have already replaced the following parts: water pump, thermostat, radiator, and coolant temperature sensor. Unfortunately, none of these replacements have been successful.
Do you have any other ideas about what might be causing this?
Thank you in advance, and best regards.
Jan.
Translated on 07-10-2026, 12:34.
dieselschrauber likes this.
Post12-05-2018, 22:58    Subject: Audi A6 TDI Overheating: Common Causes & Fixes Quote
willem4 wrote:
... the cooling water temperature quickly rises above 90°.
Yes, and?
What's the problem with that?
I wouldn't worry about temperatures up to 105-110°C.
It is important to have an ACCURATE measurement of the water temperature, and not a measurement based on AI.
Translated on 07-10-2026, 12:36.
Dieseloptimist
Post13-05-2018, 8:40    Subject: Audi A6 4B V6 TDI: Overheating Issues? Quote
What was the water temperature before you replaced the parts, when they were still working correctly? Was the cooling system properly bled? Does the fan even turn on? Does the temperature sensor react quickly? What would your desired temperature be, 75°C? Can everything be programmed via OBD-2?
Translated on 07-10-2026, 12:37.
willem4
Post13-05-2018, 9:01    Subject: Audi A6 4B: Overheating V6 TDI Engine Problem Quote
Bertil wrote:
Yes, and?
It is important to have an ACCURATE measurement of the water temperature, and not a measurement taken via AI.
"I agree, especially if the temperature, say, on a hot day with a trailer and going uphill, exceeds 90°C. But under normal driving conditions at 140 km/h, the engine should easily handle it without much strain or overheating."
Before replacing the parts, I was already experiencing these problems. During the timing belt replacement, I also replaced the water pump and thermostat, and I thought that would solve the issue. I had previously replaced the radiator at the same time as a faulty air conditioning condenser. But, as I said, the effect remains the same.
Both the electric fan and the viscous fan are running.
It might actually be the combination instrument. I'll read the temperature from the engine control unit while driving over the next few days and then compare those values with the readings from the instrument cluster.
Translated on 07-10-2026, 12:39.
Post13-05-2018, 10:22    Subject: Audi A6 4B V6 TDI: Overheating Issues? Quote
Dieseloptimist wrote:
What was the water temperature like before you replaced the parts, when they were still working correctly? Has the cooling system been properly bled? Does the fan even turn on? Does the temperature sensor react quickly? What would your desired temperature be, 75°C or something? Can everything be coded via OBD-2?
@Dieseloptimist: This is now the third nonsensical "foam party" post from you this Sunday morning, is that really necessary?
Translated on 07-10-2026, 12:41.
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Brake fluid change Audi A4 8K Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 CRB: Hot News & Updates Gasoline Engine Technology
No new posts VW Touran Rear Brakes Overheating - Fix! Transmission, Chassis, Body & Interior
No new posts AGR valve not being activated, Audi A2 1.2 TDI EDC15 Diesel Engine Technology
No new posts AFN is trending Diesel Engine Technology
