VCDS: 1.6 TDI Quantity Deviation Troubleshooting
taxidriverpro
Post17-01-2019, 19:56    Subject: VCDS: 1.6 TDI Quantity Deviation Troubleshooting Quote
Hello everyone,
I tried to display the cylinder quantity deviation in the engine control unit.
Unfortunately, I can't find those channels under the "advanced" settings. They should be IDE000365 and following... But I don't have those listed. What could be the reason for this?
Thank you and best regards.
Fredy.
 File size:  499.72 KB
 Viewed:  943 times
Translated on 04-09-2026, 10:28.
Post17-01-2019, 20:04    Subject: VCDS: 1.6 TDI Quantity Deviation Troubleshooting Quote
The numbers vary depending on the control unit. You can either find them and save them for your engine control unit, or you can use the search function in the list within the program.
Translated on 04-09-2026, 10:29.
Karma: +1336 / -0   Thank you, like it!
Post17-01-2019, 21:31    Subject: VCDS: 1.6 TDI Quantity Deviation Troubleshooting Quote
Which 1.6L TDI engine? These values are not available for the DDYA engine.
Translated on 04-09-2026, 10:30.
taxidriverpro
Post17-01-2019, 21:34    Subject: VCDS: 1.6 TDI Quantity Deviation Troubleshooting Quote
I've already searched for all sorts of things, but I haven't found anything related to "quantity."
taxidriverpro
Post17-01-2019, 22:52    Subject: VCDS: 1.6 TDI Quantity Deviation Troubleshooting Quote
Herbert wrote:
Which 1.6 l TDI? These values are not available for the DDYA engine.
That must be a CXXB, according to the vehicle identification plate.
According to Wikipedia, it should be the CRKB.
Translated on 04-09-2026, 10:31.
Post18-01-2019, 19:24    Subject: VCDS: 1.6 TDI Quantity Deviation Troubleshooting Quote
taxidriverpro wrote:
I have also searched for all sorts of things, but I haven't found anything related to quantity...
Then you probably didn't look properly. icon_idea.gif Actually, everything is very easy to find if you use the search function in the advanced measurement blocks in VCDS.
In the top part of your image, you just need to type where the cursor is blinking.
Where is the Autoscan? icon_idea.gif Then we don't have to speculate.
Translated on 04-09-2026, 10:32.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Adaptation channels in TDI engines Troubleshooting & Guides
No new posts Quantity deviation after injector replacement Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Golf TDI: Stuttering When Coasting to a Stop Diesel Engine Technology
No new posts Is an internet connection mandatory when accessing ECUs? On-Board Diagnostics (OBD)
