Polo 6R1: Steering Assist Control Unit Coding
sw1981j
Post08-04-2019, 11:40    Subject: Polo 6R1: Steering Assist Control Unit Coding Quote
Hello everyone,
After replacing the motor pump unit (manufacturer: TRW), including the control unit for power steering, on a Polo 6R1, I am unfortunately unable to correctly configure the control unit because the LogIn option is not displayed in VCDS.
Can anyone help me with this? Is there a way to find the login information?
Thank you in advance!
Translated on 02-10-2026, 19:41.
Post08-04-2019, 17:54    Subject: Polo 6R1: Steering Assist Control Unit Coding Translating...
[Translating...]
Autoscan?
sw1981j
Post08-04-2019, 18:24    Subject: Polo 6R1: Steering Assist Control Unit Coding Quote
Sorry, please see the attachment.
Log-WVWZZZ6RZCY218928-101750km.txt
 File name:  Log-WVWZZZ6RZCY218928-101750km.txt
 File size:  8.47 KB
 Downloaded:  613 times
Translated on 02-10-2026, 19:42.
vag-driver
dieselschrauber likes this.
Post10-04-2019, 9:20    Subject: Polo 6R1: Steering Assist Control Unit Coding Quote
After reviewing your scan, I have the following comments:
1. Address 56: Radio.
"This indicates low voltage."
Is your battery okay?
2. Address 44: Steering assist.
Clearly, there's a power outage.
Check the sensor and inspect the lines for damage.
Are the part numbers identical? Were new or used parts installed?
Andreas
Translated on 02-10-2026, 19:43.
sw1981j
Post11-04-2019, 18:44    Subject: Polo 6R1: Steering Assist Control Unit Coding Quote
The undervoltage has probably been stored for quite some time.
The problem was the power steering control unit, including the pump. We completely replaced it. The steering is now working perfectly again. However, the correct coding was missing for the new control unit. That's also why there was an error with the sensor. This sensor is not even installed on my Polo, and I wanted to properly code it using VCDS, but I can't access the coding section because I don't have the login credentials.
Due to a lack of time, I had to have it programmed by a professional this time. Everything is working again now.
Why doesn't the login code sometimes appear? If it did, I could have coded it myself. Or is this code stored somewhere? It would be great to know. Thanks anyway!
Translated on 02-10-2026, 19:44.
Post11-04-2019, 19:29    Subject: Polo 6R1: Steering Assist Control Unit Coding Quote
sw1981j wrote:
The undervoltage has probably been stored for a longer period.
The problem was the power steering control unit, including the pump. We completely replaced it. The steering is now working perfectly again. However, the correct coding was missing for the new control unit. That's also why there was an error with the sensor. This sensor isn't even installed on my Polo, and I wanted to properly code it using VCDS, but I can't access the coding section because I don't have the login credentials.
Due to a lack of time, I had to have it programmed by a professional. Everything is working again now.
Why is the login code sometimes not displayed? Then I could have coded it myself. Or is this code stored somewhere? It would be great to know. Thanks anyway!
Login codes are usually stored in the label file for the respective control unit. Sometimes, it can also be helpful to check the label file for a technically similar control unit.
-> Always include the Autoscan results so it's clear which control units are being discussed.
Translated on 02-10-2026, 19:46.
No new posts HEX-V2: Login failed Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Coding Daytime Running Lights - How To Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N Steering Wheel Removed -- On-Board Diagnostics (OBD)
No new posts Steering Assist Control Unit Error Transmission, Chassis, Body & Interior
No new posts Oktavia RS Steuergerät für Lenkhilfe anpassen On-Board Diagnostics (OBD)
No new posts Golf 5 - Steering assistance control unit - Implausible s... Transmission, Chassis, Body & Interior
