Differenzdrucksensor kein Zugang | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » On-Board Diagnostics (OBD)
Uwe
Post04-05-2019, 8:45    Subject: Quote
This is what the auto-scan reported.
The brake or ESP system has an error. That's why I'm looking into it. The climate control also occasionally displays incorrect values, but not always. I'll run another car scan later to see if they are communicating with each other.
That's exactly my problem. With both vehicles, I don't have reliable access to all the control units, and I experience many disconnections, which is curious because it never happens with the engine control unit.
Kundenservice bedeutet bei Audi, die Kunden so schnell ĂŒber den Tisch zu ziehen, daß sie die ReibungswĂ€rme als NestwĂ€rme empfinden!
Translated on 24-09-2026, 13:18.
Post04-05-2019, 9:01    Subject: Quote
What information do you get when you read the diagnostic interface (parts list)?
Translated on 24-09-2026, 13:19.
Uwe
Post04-05-2019, 9:52    Subject: Quote
Bulleted lists are not supported.
New scan.
Saturday, May 4, 2019, 10:50:04:00397
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 7 x86.
VCDS Version: RKS 18.9.0.2 HEX-V2 CB: 0.4436.4
Data as of: 20181004 DS296.0
http://shop.dieselschrauber.org/en
Vehicle Identification Number: VSSZZZ6LZ4R011348 License plate:
Vehicle type: 6L (6L - Seat Ibiza/Cordoba (2002 > 2009))
Scan: 01 02 03 08 09 15 17 19 25 37 44 46 55 56
Mileage: 241,470 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um draußen zu sein."
Address 01: Engine Control Module
Label file: DRV\038-906-019-ASZ.lbl
Part number: 038 906 019 DQ
Component: 1.9L R4 EDC G000SG 1536
Encoding: 00002
Operating number: WSC 06402
VCID: 698E4DB58069FA9F29B-4B1E
VSSZZZ6LZ4R011348 SEZ7Z0C2120105
2 error codes found:
17664 - Coolant temperature sensor (G62).
P1256 - 35-10 - Open circuit/short circuit after positive - Intermittent.
17911 - Generator terminal load signal.
P1503 - 35-10 - Implausible signal - Intermittent.
Readiness: 0 0 X X X
Address 03: Brake Electronics
Label file: DRV\6Q0-907-37x-ESP.lbl
Part number: 6Q0 907 379 M
Component: ESP 5.7 front, part number H03 0001.
Encoding: 0003353
Operating number: WSC 06403 000 00000
VCID: 47CAAB0DF3BDECEF1FF-50F4
"One error found:"
00526 - Brake light switch (F)
011 - Interruption.
Address 08: Climate Control/Heating. Label file: DRV\6L0-820-043.lbl
Part number: 6L0 820 043 B.
Component: CLIMAtronic PQ24 0201
Operating Number: WSC 00000 000 00000
VCID: 2516018529F11EFFCD3-50F4
6 error codes found:
00710 - Actuator motor for defrost flap (V107)
000 - - - Sporadically
01272 - Actuator motor for central locking (V70).
01274 - Actuator for pressure relief valve (V71).
01087 - Initial setup not performed.
005 - No or incorrect initial setup/adjustment.
00792 - Pressure switch for air conditioner (F129)
00819 - High-pressure sensor (G65)
Address 09: Central Electronics
Label file: DRV\6Qx-937-049-C.lbl
Part number: 6Q1 937 049 C
Component: 00 BN-SG. 1S33
Encoding: 00652
VCID: 3B22C7FDBA75B80F8B7-50F4
No error codes found.
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 6Q0 909 605 S
Part: 14 AIRBAG VW5 07 0007
Encoding: 12596
Operating number: WSC 06441
VCID: 47CAAB0DF6BDECEF1FF-50F4
Address 17: Control panel module
Label file: DRV\6L0-920-xx0-17.lbl
Part number: 6L0 920 820 K
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V10
Encoding: 00145
Operating number: WSC 00000
VCID: 323CEAD96D3F7947581-50F4
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: 60 GATEWAY CAN 1S33
Encoding: 00014
VCID: 70B820D1A3B30B576E5-50F4
Address 44: Steering Assist
Label file: DRV\6Q0-423-156.clb
Part number: 6Q0 423 156 S
Component: Power Steering Unit - TRW - V260.
Encoding: 10121
VCID: 3FDAB3EDAE6DA42FA7F-50F4
Address 46: Comfort System
Label file: .DRV\6Q0-959-433.clb
Part number: 6Q0 959 433 E
Component: 02 Comfort Device, 0002.
Encoding: 00065
Operating number: WSC 42544
VCID: 3D26C9E5A461B63FB53-4B1E
Subsystem 1 - Part number: 6Q2959802C
Part: 02 Door control unit.FS KLO 0003
Subsystem 2 - Part number: 6Q2959801C
Component: 02 Door control unit.BF KLO 0003
End--(Duration: 02:35, Battery voltage start/end: 12.0V/12.0V. Vignette: 0.0V)----
Translated on 24-09-2026, 13:30.
Post04-05-2019, 10:36    Subject: Quote
That's exactly my problem. With both vehicles, I don't have reliable access to all control units, and I experience many disconnections, which, curiously, never happen with the engine control unit.
When experiencing connection problems, also keep an eye on the on-board voltage... and
VIgn 0.0V
leave the ignition on!
Translated on 24-09-2026, 13:42.
No new posts P2453: DPF Differential Pressure Sensor Error Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential pressure sensor G450 to be calibrated/adjust... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts DPF differential pressure sensor output voltage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Differential Pressure Sensor: Explained Diesel Engine Technology
No new posts Differential Pressure Sensor T5 On-Board Diagnostics (OBD)
No new posts Differential Pressure Sensor Diesel Engine Technology
No new posts When is a differential pressure sensor dead? Diesel Engine Technology
