Robby
Joined: 11/21/2018 Posts: 8 Karma: +1 / -0 Location: NĂ€he Kiel
15-05-2019, 17:00 Subject: Upgrade UHV Low to Premium |
I replaced the control unit #77 from 1K8 035 730 B to 5K0 035 730 E in my Passat (B6, Variant, 2009 with RNS510 and iPhone  . After the replacement, the UHV-Premium system actually worked perfectly: audio playback via Bluetooth works, the phone dialog is visible in the MFA...
Then, I reset the learning values of the new control unit because I couldn't activate the supply voltage to the handphone casing.
Now I can pair the iPhone, and then a message appears in the MFA (Multi-Function Display) saying "New device found," followed by a prompt to set up a user profile. However, I can't interact with this dialog because the arrow buttons and the OK button on the steering wheel don't respond to input within this dialog.
Can anyone help me with this problem? Thank you.
Wednesday, May 15, 2019, 1:22:29:47185
VCDS, a Windows-based VAG/VAS emulator, runs on Windows 10 x64 (using Parallels).
VCDS Version DRV 18.9.0.2
Data as of: 20181017 DS296.0
www.Ross-Tech.de
Dealer/Workshop name: --
Vehicle Identification Number: WVWZZZ3CZ9E133149
License plate: --
Mileage: 113,880 km. Repair order:
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Vehicle type: 3C-VW46 (3C0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
69 72 77
Mileage: 113,880 km
01-Motor electronics -- Status: OK 0000
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08-Climate control/heating unit -- Status: OK 0000
09-Central Electrical System -- Status: OK.
Parking Assist 10 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: Error 0010.
42-Volt electric vehicle driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Comfort System -- Status: OK 0000
4F Main Electrical System II -- Status: OK 0000
52-inch electric auxiliary passenger seat -- Status: OK 0000
53-Parking brake -- Status: OK 0000
56-Radio -- Status: Error 0010.
61-Battery regulation -- Status: OK 0000
62-High voltage circuit breaker, high current -- Status: OK 0000
69-pin connector -- Status: OK.
72-volt electrical, high, right -- Status: OK 0000
77-Phone -- Status: Error 0010.
Address 01: Engine Control Module (ECM)
Label file: DRV\03L-906-022-CBA.clb
Part number SW: 03L 906 022 MS, HW: 03L 907 309 B.
Part: R4 2.0l TDI G000SG 9977
Revision: 22H21--- Serial Number: VWZCZ000000000
Encoding: 0000071
Operating number: WSC 43140 001 1048576
VCID: 020DEF105DB7405AC3-8057
No error codes found.
Readiness: 0 0 0 0 0
Address 03: Brake Electronics
Label file: DRV\3C0-614-109-C4.clb
Part number SW: 3C0 614 109 M, HW: 3C0 614 109 M.
Component: J104 C4 440 V2 0021
Revision: --025--- Serial Number: 00000795123361
Encoding: 0033272
Operating number: WSC 05311 000 00000
VCID: 28599DB89B4B4A0ABD-807D
Address 08: Climate Control/Heating. Label file: DRV\1K0-820-047.lbl
Part number SW: 1K0 820 047 JE Hardware number: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial Number: 00000000000000
Operating Number: WSC 00000 000 00000
VCID: 70E9B5D8631B42CA25-8025
Address 09: Central Electronics Label file: .DRV\3C0-937-049-30-H.lbl
Part number SW: 3C8 937 049 R Hardware: 3C8 937 049 R
Component: On-board network module H53 3101.
Revision: 00H53000 Serial Number: 00000009384796
Encoding: E1888F0700041A00470A00000F00000000015D435C000120000100000000
Operating number: WSC 05124 000 00000
VCID: 40892518133B924A95-8015
Subsystem 1 - Part number: 3C1 955 419 B
Label file: DRV\1KX-955-119.CLB
Part: Wiper 180209 005 0208
Encoding: 00046997
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 310309 054 0402
Encoding: 00208936
Address 10: Parking Assist 2 (J446) Label file: .DRV\3C8-919-475.clb
Part number SW: 3C8 919 475 A, HW: 5K0 919 475 E.
Part: PARKING ASSIST 8K H01 0009
Revision: -------- Serial Number: 12531335400618
Encoding: 110001
Operating number: WSC 12345 123 12345
VCID: 326D7FD06D9730DA13-8067
Address 15: Airbag
Label file: DRV\5N0-959-655.lbl
Part number SW: 5N0 959 655 J, Hardware number: 5N0 959 655 J.
Part: J234__003 VW10 HI 1916
Revision: 20013000 Serial Number: 003E2P6C1E90
Encoding: 0012339
VCID: 4481290807238E6AB1-8011
Subsystem 1 - Serial number: 6332MTS630950609.
Subsystem 2 - Serial number: 6342MTS647760269.
Subsystem 3 - Serial number: 6351HTS65QDLV5KR
Subsystem 4 - Serial number: 6361HTS60F6LV5KR
Subsystem 5 - Serial number: 0000000000000000
Subsystem 6 - Serial number: 0000000000000000
Address 16: Steering wheel electronics
Label file: DRV\3C0-953-549-SW20.lbl
Part number SW: 3C0 953 549 AE, Hardware number: 3C0 953 549 AE.
Component: J0527 0020
Revision: 00026000 Serial Number: 3C9953507CP
Encoding: 0000112
Operating number: WSC 05314 000 00000
VCID: 6FEBB6A47E255D323C-803B
Subsystem 1 - Part number: XXXXXXXXXXX
Component: E0221 002 0030
Address 17: Control panel module (J285)
Label file: | DRV\3C8-920-xxx-17.clb-SRI1
Part number SW: 3C0 920 871 T, HW: 3C0 920 871 T.
Component: KOMBI H05 0110
Encoding: 160F00
Operating number: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
VCID: 356744CC94F927E236-8061
Address 19: Diagnostic interface
Label file: .DRV\3C0-907-530-V3.clb
Part number SW: 3C0 907 530 M, HW: 3C0 907 951.
Component: J533__Gateway H14 0158
Revision: H14 Serial Number: 0721G09318022B
Encoding: F9A07F46400603042002
Operating number: WSC 46051 123 173335.
VCID: 2B5362B48ABD611250-807F
Address 25: Immobilizer
Label file: DRV\3C0-959-433-25.clb
Part number SW: 3C0 959 433 AR HW: 3C0 959 433 AR
Component: IMMO 043 0383
Revision: 00043000 Serial Number: VWZCZ000000000
Operating number: WSC 131071 1023 2097151
VCID: 7AFD97F03567089A9B-802F
Subsystem 1 - Part number: 3C0 905 861 G
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 37: Navigation (J0506)
Label file: .DRV\1T0-035-680.clb
Part number SW: 1T0 035 680 P Hardware: 1T0 035 680 P
Component: RNS-MID H10 5230
Revision: AB001001 Serial Number: VWZ6Z7J8152026
Encoding: 04000400010000920011
VCID: 3B7352F4BADDF192C0-806F
Subsystem 1 - Part number: 1T0 919 859 B
Component: EU West V15 8515.
"One error found:"
01303 - Transmitting and receiving device for telephone (R36).
004 - No signal/communication - Intermittent.
Environmental conditions:
Error status: 00100100
Error priority: 5
Error frequency: 1.
Lost Count: 49
Mileage: 113,886 km
Time: 0.
Date: 2013.10.05
Time: 11:16:38
Address 42: Tire pressure sensor driver
Label file: .DRV\1K0-959-701-MIN3.clb
Part number SW: 1K0 959 701 AC, HW: 1K0 959 793 N.
Component: J386 DOOR-SG FT 1517
Revision: 72009005 Serial number: 00000684898227
Encoding: 0000181
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 J, Hardware number: 5N1 909 148 F.
Component: J500__APA-BS, Class 081, 0503.
Revision: 1AH02250 Serial Number: 00090380029802
Coding: 0000258
VCID: 397F48FC70E1C382D2-806D
Address 46: Comfort System; Label file: .DRV\3C0-959-433-46.clb
Component: KSG PQ46 ELV 043 0612
Encoding: 1891020051034E763004941570084F0E707C01
Operating number: WSC 05311 123 12345
Subsystem 1 - Part number: 1K8 951 605.
Component: LIN BACKUP HORN H09 9002
Subsystem 2 - Component: NGS, not mounted.
Subsystem 3 - Component: IRUE, not mounted.
Address 4F: Central Electrics II (J533_)
Label file: .DRV\1K0-907-532.clb
Part number SW: 1K0 907 532, HW: 3C0 907 951.
Revision: -------- Serial Number: 0721G022B09318
Encoding: 00000000
VCID: 66C5D38091DF9C7A4F-8033
Address 52: Auxiliary electrical equipment for front passenger seat. Label file: .DRV\1K0-959-702-MIN3.clb
Part number SW: 1K0 959 702 AC, HW: 1K0 959 792 N.
Component: J387 DOOR-SG BT 1517
Revision: 72009005 Serial number: 00000760598213
Encoding: 0000180
Address 53: Parking brake
Label file: DRV\5N0-907-801.clb
Part number SW: 3C8 907 801 A, HW: 3C8 907 801 B.
Part number: J540 EPB3 VW-10498 0003.
Revision: 010 Serial number: 00000000036019
Coding: 0000056
Address 56: Radio (J0506) Label file: .DRV\1T0-035-680.clb
"One error found:"
Error priority: 5
Error frequency: 1.
Lost Count: 49
Mileage: 113,886 km
Time: 0.
Date: 2013.10.05
Time: 11:16:38
Address 61: Battery Management (J840)
Label file: .DRV\1K0-907-534.clb
Part number SW: 1K0 907 534, HW: 3C0 907 951.
Component: Battery control unit H14 0158.
Encoding: 0301085A
VCID: 68D9DDB89BCB8A0A7D-803D
Subsystem 1 - Part number SW: 1K0 915 181 B, HW: 1K0 915 181 A.
Component: J367-BDM H07 0121
Serial number: 00000000002786400628
Address 62: Torque sensor, high/low. Label file: .DRV\1K0-959-703-GEN3.clb
Part number SW: 1K0 959 703 AB, HW: 1K0 959 795 L.
Component: J388
Part Name: DOOR-SG HL
Code: 0307
Revision: 41004101 Serial Number: 00000000865219
Encoding: 0000144
Address 69: Trailer (J345) Label file: .DRV\1K0-907-383-V2.clb
Part number SW: 1K0 907 383 E, HW: 1K0 907 383 E.
Component: Trailer H08 0080
Revision: 3A002002 Serial number: 00000117764900
Encoding: 4100000100000000
VCID: 2F6B76A47EA51D327C-807B
Address 72: Throttle valve, high, right. Label file: .DRV\1K0-959-704-GEN3.clb
Part number SW: 1K0 959 704 AB, HW: 1K0 959 794 L.
Component: J389
Part: DOOR-SG HR
Code: 0307
Revision: 41004101 Serial Number: 00000000860775
Encoding: 0000144
VCID: 71EFB0DC68114BC22A-8025
Address 77: Phone (J412)
Label file: | DRV\7P6-035-730.clb
Part number SW: 5K0 035 730 E, Part number HW: 5K0 035 730 E.
Component: TELEPHONE H09 2902
Revision: 1B001001 Serial Number: 00007662449907
Encoding: 0111040000000010
Operating number: WSC 01383 790 50316
ASAM Dataset: EV_UHVNA A01719
ROD: UHVNA.rod
VCID: 275B9E845E554572B4-8073
"One error found:"
13636608 - Control unit incorrectly coded.
U1014 00 [009] - -
confirmed - checked since last deletion.
Error status: 00000001
Error priority: 4
Error frequency: 1.
Lost Count: 10
Mileage: 113,886 km
Date: 2019.05.15
Time: 13:06:41
End----------------------------(Duration: 03:09)-----------------------------
| Description: |
 Download |
| File name: |
Log-WVWZZZ3CZ9E133149-113880km.txt |
| File size: |
14.36 KB |
| Downloaded: |
503 times |
brauche keine Handschuhe
Translated on 07-10-2026, 12:37.
Joined: 04/12/2002 Posts: 18132 Karma: +804 / -0 Location: St.Gallen 2018 Volkswagen T6
19-05-2019, 7:35 Subject: Upgrade UHV Low to Premium |
Hello.
Quote: | | I cannot use this dialog because the arrow keys and the OK button on the steering wheel do not respond to this dialog. |
The newly installed control unit is either incompatible with the vehicle or has been incorrectly programmed.
Translated on 07-10-2026, 12:38.
Profile PM WWW Garage |
Robby
dieselschrauber likes this. |
19-05-2019, 14:54 Subject: Upgrade UHV Low to Premium |
Could a steering wheel with a DDP protocol be installed even with a white MFA (multifunction display)? In that case, the new UHV (unit head) would not perform automatic pairing and would not be able to respond to the buttons, as it uses the BAP protocol.
But how can the RNS510 in the MFA's radio interface respond to inputs from the steering wheel, even though it uses the BAP protocol, and all other interfaces within the MFA also respond to the steering wheel?
Would a steering wheel with BAP protocol fix these problems?
The error message:
"One error found:"
It's due to the setting that enables the phone charging case feature.
I wanted to continue using the charging dock, but only for charging my phone.
Translated on 07-10-2026, 12:39.
