Replacement MFL (multifunction leather steering wheel) with 12 buttons for a 2009 Passat B6
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
Robby
Post07-08-2019, 21:11    Subject: Replacement MFL (multifunction leather steering wheel) with 12 buttons for a 2009 Passat B6 Quote
It all started with the upgrade from UHV-Plus to UHV-Premium. Here is a request from me on the topic: /viewtopic.php?p=245947#245947.
Okay, here's the translation:
"I have now exchanged the following units:"
- New MFL: 3C8419091BEE74 from VW 3C Passat, complete with airbag and 12 buttons.
- From a reliable source, a new steering column control unit (part number 3C0 953 549AH) with a new coding: 0200512.
- UHV component: 1K8 035 730 B replaced by 5K0 035 730 E.
So far, the new MFL is working wonderfully: the UHV-Premium can be accessed (user profiles, address book, call lists, etc.), and the MFA responds to the new MFL, providing all the functions as before, plus the phone functions in the MFA and the RNS 510.
The only downside:
- Part 03: Brake electronics.
"1 error found:"
00778 - Steering angle sensor (G85)
005 - No or incorrect initial settings/adaptation.
- Steering assist system 44:
4 error codes found:
00566 - Power steering operation.
008 - Implausible signal - Warning light ON.
Environmental conditions:
Error status: 11101000
Error priority: 1
Error frequency: 1
Lost Count: 75
Mileage: 117,283 km
Time: 0
Date: 2013.12.28
Time: 20:39:60
Hex Value: 0x7301
Hex Value: 0x7601
Hex Value: 0x7301
Hex Value: 0x7601
Hex Value: 0x7301
02546 - Steering end stop.
005 - No or incorrect initial setting/adaptation - Warning light ON.
Error status: 11100101
Error priority: 2.
Error frequency: 1
Lost Count: 75
Mileage: 117,283 km
Time: 0
Date: 2013.12.28
Time: 20:39:60
Class 15, Entry.
Speed: 779 RPM.
Speed: 0.0 km/h
(no unit): 7.0
Voltage: 14.20 V
Error priority: 2.
Error frequency: 1
Lost Count: 75
Mileage: 117,283 km
Time: 0
Date: 2013.12.28
Time: 20:39:60
(no unit): 7.0
Steering angle: 0.00°
n.i.O.
(no unit): 12
008 - implausible signal.
Error status: 01101000
Error priority: 1
Error frequency: 1
Lost Count: 75
Mileage: 117,283 km
Time: 0
Date: 2013.12.28
Time: 20:39:60
(no unit): 7.0
n.i.O.
(no unit): 12
- Extension 77, Phone:
"1 error found:"
13636608 - Control unit incorrectly coded.
U1014 00 [009] - -
confirmed - checked since last deletion.
Error status: 00000001
Error priority: 4
Error frequency: 1
Lost Count: 75
Mileage: 117,283 km
Date: 2019.08.07
Time: 20:40:01
The MFL had been reassembled due to the errors, but could be...
No errors detected (all cables connected).
Can someone help me? I would be happy.
Robert
Log-MFL-NEU-WVWZZZ3CZ9E133149-117280km.txt
 File name:  Log-MFL-NEU-WVWZZZ3CZ9E133149-117280km.txt
 File size:  16.19 KB
 Downloaded:  650 times
brauche keine Handschuhe
Post08-08-2019, 12:14    Subject: Replacement MFL (multifunction leather steering wheel) with 12 buttons for a 2009 Passat B6 Quote
Hello, I might be wrong, but it seems to me like this could be a simple issue of a missing basic calibration of the control unit. Has this been done? Having problems with it!
Robby
Post08-08-2019, 12:22    Subject: Replacement MFL (multifunction leather steering wheel) with 12 buttons for a 2009 Passat B6 Quote
Yes, I have now calibrated the steering angle sensor. I've performed the alignment multiple times, but the steering wheel still has a slight leftward offset (approximately 5 degrees) when driving straight.
I only have one error left, in section 77. I've re-coded almost every single-digit number once, but the error keeps recurring.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Starter Cable Problems: Troubleshooting & Solutions Troubleshooting & Guides
No new posts Generator free wheel defective - slipping Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Replacing the steering wheel of a 2009 VW Passat B6 with ... Electrical Systems, Vehicle Electronics, Multimedia
This topic is locked, you cannot edit or reply. EPB Problem: Passat 3C, 2009 Model Transmission, Chassis, Body & Interior
No new posts Passat 2009 power loss Diesel Engine Technology
This topic is locked, you cannot edit or reply. P2563 Passat CC: Diagnose & Lösungen (2.0 TDI) Diesel Engine Technology
