Sharan 7N crack in the body panel
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
vag-driver
Post05-12-2019, 9:11    Subject: Sharan 7N crack in the body panel Quote
"Recently, I've noticed a clicking sound coming from the front drivetrain when driving at a slow speed in the following situations:"
1. When turning the steering wheel sharply without changing gears, for example, when maneuvering while parking.
2. When shifting between gears D and R, and also when turning the steering wheel sharply.
It sounds like a noise made when metal is relaxing.
Where can I start looking here? The situation is not currently 100% reproducible.
Andreas
Post05-12-2019, 19:17    Subject: Sharan 7N crack in the body panel Quote
Hi.
Is the dome light stuck?
vag-driver
Post06-12-2019, 9:25    Subject: Sharan 7N crack in the body panel Quote
I had the Sharan on the lift yesterday, and I couldn't find anything that could be causing the cracking noise. The wheels turn smoothly.
I replaced the stabilizer bars with Meyle HD ones this summer. They are noticeably stiffer and less flexible. Could it be that this creates more tension?
Andreas
Post06-12-2019, 11:48    Subject: Sharan 7N crack in the body panel Quote
Are the strut mounts under stress when the wheels are not in contact with the ground? icon_question.gif
vag-driver
Post06-12-2019, 12:01    Subject: Sharan 7N crack in the body panel Quote
They are under pressure. But by tension, not by pressure.
Andreas
Post06-12-2019, 15:28    Subject: Sharan 7N crack in the body panel Translating...
[Translating...]
Karma: +585 / -0   Thank you, like it!
dieselschrauber, Rüdi and Herbert likes this.
Post06-12-2019, 18:07    Subject: Sharan 7N crack in the body panel Quote
Hi!
When I encountered such problems, I used the diagnostic tools in a pit.
The car will then be in the same conditions as it would be on the road.
My father, despite his age, is a careful and clever person who, when in a car, can drive forward, backward, steer, and even engage the handbrake.
Only that person is not allowed to drive into the pit.
I then got down on the ground under the car and tried to listen for any cracking sounds.
Then I manually examined the suspicious parts.
I have always had a very good success rate with this method.
In the described case, I would also check if the strut mounts are stiff or difficult to move under load, and if the springs are broken.
I would also generally view dome supports with a critical eye. Hopefully, you've installed it correctly.
vag-driver
Post11-12-2019, 9:03    Subject: Sharan 7N crack in the body panel Quote
Steffen G wrote:
I would also generally view dome supports with a critical eye. Hopefully, you have it properly installed.
I didn't do anything at the storage facility. I replaced the support brackets (the ones that connect the lower control arm to the chassis).
The feathers are not broken. I have already checked them. Since I don't have a pit available, it will be difficult to test it under load.
Interestingly, I'm not experiencing that cracking sound right now. Perhaps it's temperature-dependent.
Andreas
No new posts Cracking noise from rear axle, Audi A6 4F Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts MKB ANU Engine Noises: Documentary Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku Sharan 7M9, Engine Noises at MKB ANU Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Front axle cracking - Sharan 7N Transmission, Chassis, Body & Interior
No new posts Rear Axle Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Knacken an der Vorderachse Transmission, Chassis, Body & Interior
No new posts Steering Wheel Lock & Crack: Causes & Fixes Transmission, Chassis, Body & Interior
