Schraubenabreisser
Joined: 02/29/2020 Posts: 19 Karma: +0 / -0 Location: Worms
24-03-2020, 8:17 Subject: |
Thank you for your inquiry.
Unfortunately, there's nothing new to report. I went on several test drives on Saturday and Sunday without any success. I also tried disconnecting the battery for 2 hours, but that didn't help either.
According to the error message in the brake control unit:
01044 - Control unit incorrectly programmed.
00778 - Steering angle sensor; calibration not performed.
01119 Signal for pedestrian detection (sporadic).
and in the MSTG:
18057 - Data bus fault, drive - P1649-35-00 - Missing message from the ABS control unit.
Unfortunately, there are increasingly more errors. The login for coding is not being accepted, and the coding in the BSTG system is set to 00000, which means I cannot make any changes.
Apparently, the coding might have been activated by the brake system test and then lost when I deactivated it in block 103, without being saved in VCDS.
Right now, I don't think I can fix the problem, even with your support. Is there another idea, or should I post another Autoscan?
Otherwise, my only option is to go to my preferred workshop, which is something I'd actually prefer to avoid.
Best regards, Marco. Fahrzeuge:
Passat 3BG V6 TDI 4 Motion MKB BAU, Golf IV TDI, Golf III GT AFN, diverse T3
Translated on 04-09-2026, 6:05.
Joined: 04/12/2002 Posts: 18097 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
24-03-2020, 22:36 Subject: |
Hello.
Oh man, the error code for your brake control module, 04457, is listed in the car scan data that you yourself posted.
You don't even mention the system function test anymore, and I suspect it's long outdated.
Possibly, there is a need for knowledge about which function is used for what. Have you already read and understood the VCDS manual?
My advice would be not to perform any work on vehicle components that are critical to safety if you don't understand what you are doing.
Translated on 04-09-2026, 6:07.
Profile PM WWW Garage |
Schraubenabreisser
25-03-2020, 16:45 Subject: |
Hello Rainer,
Yes, the Autoscan from the week before last included the coding. Unfortunately, as mentioned before, it's no longer doing that now; everything is showing as 0000. I suspect that the "click system test" I set in block 103 is the reason it's stopped.
The system test is still ACTIVE, and I have intentionally not deleted any codes. I still cannot even access the login screen with the code 40168, so I cannot enter the codes 04457 and 05311, even if I try repeatedly; nothing is saved. Also, nothing is saved even after turning the ignition on and off.
I've read the manual and I think I understand it. I printed it out from a different source because the one here is read-only and printing is disabled.
As a beginner, I have been intensively exploring the software, but unfortunately, so far without success and certainly with beginner mistakes  .
Thank you for the advice, but I only wanted to bleed the brakes. Now I'm dealing with coding, which wasn't my goal.
Maybe there's still a chance, I would be happy to hear it.
Translated on 04-09-2026, 6:09.
25-03-2020, 18:37 Subject: |
Tip: Post a snapshot of the current state.
Translated on 04-09-2026, 6:11.
Schraubenabreisser
26-03-2020, 7:19 Subject: |
Attached is the information from this morning.
Vehicle type: 3B (3B - VW Passat B5 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 19 35 36 37 46 47 55 56 57 58 75 76 77
Vehicle Identification Number: WVWZZZ3BZ4E185856
Mileage: 295,180 km
"Die Sonne scheint hell, und die Vögel zwitschern fröhlich. Ein leichter Wind weht durch die BĂ€ume, und die BlĂ€tter rascheln leise. Es ist ein wunderschöner Tag, um drauĂen zu sein."
Address 01: Engine Control Unit
Label file: DRV\059-907-401-AKE.clb
Part number: 8E0 907 401 J
Part: 2.5l/4VTEDC G000AG 0005
Encoding: 03006
Operating number: WSC 05314
VCID: 2C141A60DE3CAE2F2A-4AE0
Subsystem 1 - Part number: 00006059
Component: 130 106LC150_1.V79820195390
WVWZZZ3BZ4E185856 VWZ7Z0C8517387
"One error found:"
00550 - Injection start control.
08:00 - Limit exceeded.
Readiness: 0 0 X X X
Address 02: Transmission Label file: DRV\01V-927-156.lbl
Part number: 8D0 927 156 EA
Part number: AG5 01V 2.5l TDI, Roadworthy certificate 2223.
Encoding: 01101
Operating number: WSC 05311
VCID: 70ACCE1032948ACF56-5118
No error codes found.
Address 03: Brake Electronics Label file: DRV\4B0-614-517.lbl
Part number: 4B0 614 517 H
Component: ABS/ESP all-wheel drive 3428.
Coding: 00000
Operating number: WSC 00000
VCID: 2600E848C0D0947FFC-51A8
3 error codes found:
01044 - Control unit incorrectly coded.
35-00 - -
00778 - Steering angle sensor (G85)
66-10 - Synchronization not performed - Intermittent.
18265 - End-of-line signal.
P1857 - 35-10 - Error message from the engine control unit - Intermittent.
Address 08: Climate Control Module. Label file: DRV\3Bx-907-044.lbl.
Part number: 3B1 907 044 J
Component: CLIMATRONIC B5GP 0006
Encoding: 17000
VCID: 281CE670CAC4820FCE-513C
2 error codes found:
00603 - Actuator motor for footwell/defrost flap (V85)
37-10 - defective - intermittent.
01272 - Actuator motor for central locking (V70).
Address 15: Airbag
Label file: DRV\6Q0-909-605-VW5.lbl
Part number: 1C0 909 605 C
Part number: 0E AIRBAG VW61 04 0003.
Encoding: 12357
VCID: 2404F240B6EC666FE2-50F4
"One error found:"
00532 - Power supply voltage.
07-10 - Signal too weak - Sporadic.
Address 17: Control panel module
Label file: DRV\3B0-920-xx5-17.lbl
Part number: 3B0 920 849 A
Component: COMBINATION INSTRUMENT + SPEEDOMETER VDO V04
Coding: 21115
Operating number: WSC 70599
VCID: 2600E848C0D0947FFC-50F4
01316 - Brake control unit.
49-10 - No communication - Intermittent.
01326 - Control unit for multifunction steering wheel (J453)
49-00 - No communication.
Address 19: Diagnostic interface
Label file: DRV\6N0-909-901-19.lbl
Part number: 6N0 909 901.
Component: Gateway K<->CAN 0001
Encoding: 00006
VCID: 70ACCE1032948ACF56-50F4
01303 - Transmitting and receiving device for telephone (R36).
Address 37: Navigation
Label file: DRV\3B0-919-887.lbl
Part number: 3B0 919 887 H
Component: Navigation BNO 0102
Encoding: 00002
VCID: 373E350C177A1DF757-4AC2
"One error found:"
65535 - Control unit defective.
00-00 - -
Address 46: Comfort System
Label file: DRV\1C0-959-799.lbl
Part number: 1C0 959 799 B.
Component: 8S Comfort Device HLO 0003
Encoding: 00259
VCID: 362038081070E4FF4C-4AE0
Subsystem 1 - Part number: 1C1959801.
Component: 8S Control Unit.FS KLO 0202
Subsystem 2 - Part number: 1C1959802.
Component: 8S Control Unit.BF KLO 0202
Subsystem 3 - Part number: 1C0959811.
Component: 8S Control Unit.HL KLO 0202
Subsystem 4 - Part number: 1C0959812
Component: 8S Control Unit.HR KLO 0202
01135 - Sensors for interior monitoring.
36-00 - Interruption.
00931 - Rear right central locking latching unit (F223)
27-10 - implausible signal - sporadic.
Address 47: Soundsystem
Label file: DRV\1J0-035-456.lbl
Part number: 1J0 035 456 J
Component: Sound processor 3.
Encoding: 00611
Operating number: WSC 32433
"One error found:"
01311 - Data Bus Information.
Address 55: Headlight range adjustment.
Label file: DRV\4Z7-907-357.lbl
Part number: 4Z7 907 357.
Component: dynamic LWR, part number D09.
Coding: 00008
VCID: 044492C0162C866F82-4AE0
Address 56: Radio
Label file: DRV\3B0-035-186.lbl
Part number: 3B0 035 186 D
Component: Radio BNO 0102
Encoding: 00400
VCID: 200CFE50A2F47A4F86-4AC2
00852 - Front speakers.
00853 - Rear speakers.
Address 76: Parking Assist
Label file: DRV\3B0-919-283.lbl
Part number: 3B0 919 283.
Bauteil: Parkingsyst. PA RDW D01
Encoding: 01114
VCID: 6582AF44FD565F6735-5118
End --(Duration: 03:55, Battery Voltage Start/End: 12.1V/12.1V. Minimum Voltage: 12.0V)--- Fahrzeuge:
Translated on 04-09-2026, 6:27.
Schraubenabreisser
26-03-2020, 7:21 Subject: |
Translating... |
[Translating...] jetzt ist auch etwas in den CodeLog s abgelegt:
Adresse 03,4B0 614 517 H,umcodiert (Kurze Codierung),von,00000,auf,04457,(05311/---/-----),Mittwoch,25,MĂ€rz,2020,15:18:57:14233
Adresse 03,4B0 614 517 H,umcodiert (Kurze Codierung),von,00000,auf,04457,(05311/---/-----),Mittwoch,25,MĂ€rz,2020,15:25:46:14233
Adresse 03,4B0 614 517 H,umcodiert (Kurze Codierung),von,00000,auf,04457,(05311/---/-----),Mittwoch,25,MĂ€rz,2020,15:57:55:14233
Adresse 03,4B0 614 517 H,umcodiert (Kurze Codierung),von,00000,auf,04457,(05311/---/-----),Mittwoch,25,MĂ€rz,2020,16:58:26:14233
Adresse 03,4B0 614 517 H,umcodiert (Kurze Codierung),von,00000,auf,04457,(05311/---/-----),Mittwoch,25,MĂ€rz,2020,17:11:10:14233 Fahrzeuge:
Passat 3BG V6 TDI 4 Motion MKB BAU, Golf IV TDI, Golf III GT AFN, diverse T3 |
26-03-2020, 21:48 Subject: |
Translating... |
[Translating...] a) Warum hast Du 5x von 00000 auf 04457 umcodiert?
b) Warum hast Du vor dem Codierversuch keine WSC in den VCDS Programmeinstellungen eingetragen? Z.B. die, welche im Autoscan beim BremsensteuergerÀt steht.
Wenn VCDS Meldungen anzeigt, bitte diese lesen und versuchen zu verstehen. Wenn nicht hier posten. Nicht einfach Zeug wegklicken!
Ich werde den Verdacht nicht los, Du drĂŒckst hyperaktiv und ohne Nachdenken auf den Buttons im Programm herum.
Mach' das nicht. VCDS ist ein Profi-Werkzeug. Entweder man weiss was hinter der jeweiligen Aktion steckt oder man unterlÀsst diese.
Verstehst Du, was ich mit a) und b) Dir sagen will? Wenn nicht, rate ich dringend zu einem Werkstattbesuch bevor Du weiter an sicherheitsrelevanten SteuergerÀten herum fummelst und am Schluss nichts mehr funktioniert wie es soll.
Schraubenabreisser
28-04-2020, 11:28 Subject: |
Translating... |
[Translating...] Hallo Ihr,
So nach einigen Wochen und verschiedenen Helfern kann ich endlich einen Erfolg mitteilen, aber erst einmal die Antworten zum letzten Eintrag um euch möglichst einen LĂŒcken-freien Ăberblick zu geben:
zu a) mehrere Versuche mit einem ehemaligen VW Werkstattmitarbeiter, mit ZĂŒndung an,danach aus, Programm geschlossen usw. die Codierung wurde nicht angenommen.
zu b) auch WSC wurde nicht angenommen, bzw. nicht gespeichert.
Es kamen keine weitere Meldungen, somit wurde auch nichts weggeklickt. Lediglich die fehlende BestÀtigung Meldung vom Login habe ich vermisst und weiter oben schon erwÀhnt.
Nach diesen versuchen war ich in einer freien Werkstatt, der Chef probierte es ĂŒber 2 Wochen immer mal wieder mit einem Bosch Tester, konnte jedoch auch die Codierung nicht wieder herstellen.
Also machte ich einen Termin aus in einer eher kleineren VW Werkstatt aus, da ich bei so einem Problem Wert darauf lege auch mit dem Service Mitarbeiter sprechen zu können nicht das gleich wild SteuergerÀte getauscht werden.
Der erste versuch des Mitarbeiters schlug ebenfalls fehl und er kontaktierte den TechServiceCenter und bekam eine Anleitung wie er vorzugehen hatte.
Leider half diese Variante auch nicht die Codierung wieder herzustellen. Es wurde jedoch mit einer Online Hilfe des VW TSC festgestellt, das offenbar eine Sperrung des Stg. vorlag, warum auch immer. Nach Kauf eines Freischaltcodes konnte der Mitarbeiter die Codierung dann letztendlich wieder herstellen und ich zahlte 172⏠dafĂŒr. So wurde es mir zumindest mitgeteilt und ich schenke mal glauben daran.
Ich gehe mal davon aus, das ich es mit meinen Möglichkeiten nicht beheben konnte...aber bestimmt verursacht habe
Also vielen Dank fĂŒr eure Hilfe und Geduld, ich benötige bestimmt wieder mal UnterstĂŒtzung,
GruĂ Marco Fahrzeuge:
29-04-2020, 18:59 Subject: |
Translating... |
[Translating...] Dieselschrauber wrote: | | Warum hast Du vor dem Codierversuch keine WSC in den VCDS Programmeinstellungen eingetragen? Z.B. die, welche im Autoscan beim BremsensteuergerÀt steht. |
Na Hauptsache es geht jetzt, danke fĂŒr die RĂŒckmeldung! |
