Haldex clutch/Haldex axle drive 5. Which generation of oil?
Princ3
Post19-07-2020, 10:04    Subject: Haldex clutch/Haldex axle drive 5. Which generation of oil? Quote
Hello everyone,
I would like to change both the Haldex oil and the axle oil on my Skoda Octavia Scout III.
According to the identification in the repair manual, my vehicle has a 6-speed DSG transmission with the following codes: 0D9; 0CQ. (built-in) generation.
What kind of oil can be used? OE comparison number?
My research so far has unfortunately been unsuccessful, or I haven't been able to clearly determine which oil is permitted to be used.
-I would appreciate a response/link/etc. icon_smile_thumb_up.gif
Translated on 05-07-2026, 14:11.
Princ3
dieselschrauber likes this.
Post19-07-2020, 16:36    Subject: Haldex clutch/Haldex axle drive 5. Which generation of oil? Quote
Here's a quick update from my end:
-There is likely a generally applicable Haldex oil for the 5th generation. Generation: G060175A2
- For the Haldex pump, where the small filter should be cleaned, the following gasket set is available: 0CQ598305.
I'm also trying to find out which oil is needed for the Haldex all-wheel-drive system's differential. If anyone from the "ff" community knows, I would appreciate a post.
I would also appreciate it if someone could confirm whether my research on Haldex oil is correct.
Thank you and best regards.
Translated on 05-07-2026, 14:12.
Turbinchen
Karma: +75 / -0   Thank you, like it!
2014 Audi A4 Avant
Post28-07-2020, 18:16    Subject: Haldex clutch/Haldex axle drive 5. Which generation of oil? Quote
Your oil, with part number G060175A2, is correct according to my records.
The oil for the rear axle drive must be G052145S2. It should probably be a standard gear oil with a viscosity of 75W-90, but I cannot guarantee that.
Translated on 05-07-2026, 14:13.
No new posts Document 1J 4Motion, Oil Leak on Haldex Coupling Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Golf 1J1587: Haldex Control Unit Problems Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Haldex 3rd Gen Oil Change Transmission, Chassis, Body & Interior
No new posts SDI Injection Pump: First Generation On-Board Diagnostics (OBD)
No new posts Golf 4 Xenon Headlights, Generation 2 Transmission, Chassis, Body & Interior
No new posts MKB AAT Control Unit: Understanding the Values On-Board Diagnostics (OBD)
