abicim
Joined: 11/27/2020 Posts: 23 Karma: +7 / -0 Location: Furtwangen
26-02-2021, 15:52 Subject: Calibrate steering angle sensor G85 |
Hello everyone,
I have a Golf 5, and the last thing I did was replace the battery. Now, the steering wheel symbol and the ESP symbol are illuminated in yellow on the dashboard. I've tried to reset it using VCDS, following various guides from other users, but I haven't been able to get it to work. I've also tried the Rosstech guide. Can someone please help me?
Thank you in advance.
Translated on 05-07-2026, 21:32.
vag-driver Profi-Schrauber
dieselschrauber likes this. |
26-02-2021, 15:56 Subject: Calibrate steering angle sensor G85 |
Can you tell us what you have already tried? Viele Grüße
Andreas
abicim
26-02-2021, 16:02 Subject: Calibrate steering angle sensor G85 |
... Instructions that didn't work, edited by the administrator...
26-02-2021, 16:10 Subject: Calibrate steering angle sensor G85 |
Can you provide us with your car's diagnostic scan data? Viele Grüße
Andreas
Translated on 05-07-2026, 21:33.
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2401 Karma: +438 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
26-02-2021, 16:36 Subject: Calibrate steering angle sensor G85 |
Have you ever driven longer distances than just 5-10 meters?
In my hazy recollection, single-digit meters don't seem sufficient.
Guste.
Profile PM Garage |
Ich_Can_nix Profi-Schrauber
26-02-2021, 17:07 Subject: Calibrate steering angle sensor G85 |
Generally, after replacing the battery in a Volkswagen Golf 5, a diagnostic tool is not necessarily required to reset the ESP warning light.
Here, simply calibrating the limit switches and running a short distance is sufficient.
Have you tried this, or did you immediately start using the testing tool?
As Andreas already mentioned, a complete car scan would be helpful now.
Have you done anything else to the vehicle, or just disconnected/reconnected the battery?
Has the vehicle been modified?
Possibly. Is a Golf 6 steering wheel installed?
Greetings.
Translated on 05-07-2026, 21:34.
Joined: 04/12/2002 Posts: 18097 Karma: +799 / -0 Location: St.Gallen 2018 Volkswagen T6
26-02-2021, 17:20 Subject: Calibrate steering angle sensor G85 |
Hello.
guste100 wrote: | Have you ever ridden for distances longer than just 5-10 meters?
Guste |
I would have started by simply driving for 1 kilometer and trying out a few different scenarios, rather than messing around with the control units. Left, right, brakes with ABS activation, etc.
If everything is still glowing afterward, I would have investigated the reason.
"Simply disconnecting the battery" should not cause any issues.
I have deleted your collection of tutorials that didn't work, as such posts cause more problems than they solve. Exactly what one should not do is simply follow random instructions and tinker with control units without knowing what one is doing!
Where is your car scan?
Translated on 05-07-2026, 21:36.
Profile PM WWW Garage |
Rüdi Profi-Schrauber
Joined: 03/05/2005 Posts: 1508 Karma: +643 / -0 Location: Nord/Osthessen 2001 Audi A4 Avant Premium Support
20-04-2023, 7:02 Subject: Calibrate steering angle sensor G85 |
Hi.
Yesterday, a friend came by with a Golf 5 Variant, and he's having the same problem: the steering angle sensor cannot be initialized.
I need to access the steering assist control unit through the installed version, checking things like access permissions, basic settings, and channel zero calibration. I can get to that point, but the "Start" button isn't activated, so I can't click it.
There wasn't time for a longer story yesterday.
I can only provide the Autoscan feature once I've had the car for a longer period and have the necessary time to do it properly. However, it's possible I've forgotten something or am simply not smart enough to handle it.
Thank you. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Translated on 05-07-2026, 21:38.
Profile PM Garage |
Gremlin Schrauber
Joined: 08/18/2005 Posts: 395 Karma: +91 / -0 Location: Grainet 2000 Audi A4 Avant  Premium Support
23-04-2023, 7:14 Subject: Calibrate steering angle sensor G85 |
I just experienced this recently when I installed an AHK (presumably a type of electronic component) on a 2007 model.
Error message G81, steering angle sensor.
- Steering adjustments to both sides (while the engine is running) had no effect.
-Driven for a short distance, approximately 20 meters, and the error disappeared  .
Translated on 05-07-2026, 21:39.
Profile PM Garage |
23-04-2023, 8:07 Subject: Calibrate steering angle sensor G85 |
Thanks for the feedback, but unfortunately, nothing here seems to help. There's a different issue at play. I'll be running an Autoscan soon, and I'll create a new thread about this topic. Sommer: A4 B5 Avant 2,5 TDI Quattro Facelift (AKN silber)
Profile PM Garage |
