Thank you for the feedback.
vag-driver
Regarding the software version, I can't provide any further information at this time other than what is stated here. Where can I find the requested version information?
The transmission was replaced by an independent workshop because the clutch was defective (the rivets were broken), and this damage gradually led to the transmission failing. Unfortunately, I can't determine whether the sender unit is the old one.
It's a manual 6-speed transmission (TDI with 103 kW).
License plate prefix: LNZ.
Here is the complete first entry.
After clearing the codes, all errors initially disappeared. However, the engine error reappeared, along with the error in address 46 (alarm horn).
Saturday, March 13, 2021, 4:15:08 PM: 08912
VCDS â A VAG/VAS emulator based on Windows, running on Windows 10 x64.
VCDS version: RKS 20.12.0.3, HEX-V2 CB: 0.4529.4
Data as of: 20210211 DS322.1
http://shop.dieselschrauber.org/en
Dealer/Workshop name: benschke
Vehicle Identification Number (VIN): WVWZZZ3CZBE320176
License plate number: ERZ-RA74
Mileage: 207,620 km. Repair order:
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BĂ€umen. Ein leichter Wind weht durch das Gras. Es ist ein perfekter Tag fĂŒr einen Spaziergang."
Vehicle type: 3C-VW46 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 37 42 44 46 4F 52 53 56 61 62
72 77
Mileage: 207,620 km
01-Motor electronics -- Status: Error 0010.
03-Brake electronics -- Status: OK 0000
04-Steering angle sensor -- Status: OK 0000
08 - Climate Control/Heating Unit - Status: Error 0010.
09-Central Electrical System -- Status: Error 0010.
Parking Assist System 2 -- Status: OK 0000
15-Airbag -- Status: OK 0000
16-Wheel steering electronics -- Status: OK 0000
17-Terminal block insert -- Status: OK 0000
19-Diagnosis interface -- Status: OK 0000.
Immobilizer system -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Electric Driver -- Status: OK 0000
Steering assist - Status: OK 0000.
46-Comfort System -- Status: Error 0010.
4F Main Electrical System II -- Status: OK 0000
52-door electric passenger door - Status: OK 0000.
53-Parking brake -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery regulation -- Status: OK 0000
62- Door, electric, left and right -- Status: OK 0000
72-Door, electric, high, right side -- Status: OK 0000.
77-Phone -- Status: OK 0000
"Die Sonne scheint hell und warm. Die Vögel zwitschern fröhlich in den BÀumen. Ein leichter Wind weht durch das Gras. Es ist ein wunderschöner Tag."
"The sun is shining brightly and warmly. The birds are chirping happily in the trees. A gentle breeze is blowing through the grass. It's a beautiful day."
Address 01: Engine Control Module (J623-CFFB)
Label file: .DRV\03L-906-018-CFF.clb
Part number SW: 03L 906 018 BF, HW: 03L 907 309 N.
Part: R4 2.0L TDI H24 9979
Revision: 47H24--- Serial Number: 00000000000000
Encoding: 00190012042401080000
Operating number: WSC 79871 188 00000
ASAM Dataset: EV_ECM20TDI01103L906018BF 003009
ROD: EV_ECM20TDI01103L906018BF.rod
VCID: 6FBA2DF7271F21739AA-803A
"One error found:"
10088 - Gear selector for neutral position.
P15A1 00 [044] - implausible signal.
Occasionally - confirmed - checked since last deletion.
Environmental conditions:
Error status: 00000001
Error priority: 2
Mileage: 204,148 km
Date: 2020.10.12
Time: 19:13:03
Motor speed: 1326.50 rpm.
Normalized load value: 55.3%
Vehicle speed: 51 km/h
Coolant temperature: 69 °C
Intake air temperature: 12 °C
Atmospheric pressure: 950 millibars.
Voltage at terminal 30: 14.620 V.
Lost learning counter via OBD: 40.
Gear neutral position sensor: current shift angle: -6.45°.
Gear selector for neutral position: learned shift angle: 0.90°.
Voltage from the sensor for transmission neutral position: 1860 mV.
Embedded gear shift bits 0-7: 4.
Readiness: 0 0 0 0 0
Address 03: Brake electronics. Label file: 3AA-614-109.clb.
Part number SW: 3AA 614 109 M, Hardware: 3AA 614 109 M.
Component: J104 C2 450M V4F8 0005
Revision: --H07--- Serial Number: 00000003481570
Encoding: 0002480
Operating number: WSC 05311 000 00000
VCID: 372AD597134FA9B382A-8062
No error codes found.
Address 08: Climate Control/Heating (J255)
Label file: | DRV\5K0-907-044.clb
Part number SW: 5K0 907 044 EA, Part number HW: 5K0 907 044 EA.
Component: Climatronic H17 1010
Revision: 00003001
Encoding: 0000000003
Operating number: WSC 00015 115 00000
ASAM Dataset: EV_Climatronic A01010
ROD file: EV_ClimaAutoBasis_VW46.rod
VCID: 6E8430F32015287B91C-803A
"One error found:"
9481988 - Air quality sensor.
B10AF 04 [008] - defective.
Error priority: 3
Error frequency: 4
Lost Count: 0
Mileage: 204,443 km
Date: 2020.11.16
Time: 11:39:02
Address 09: Central Electronics (J519)
Label file: .DRV\3AA-937-087.clb
Part number SW: 3AA 937 087 A, Hardware: 3AA 937 087 A.
Part number: BCM PQ47 H, 413 0452.
Revision: BB413001
Encoding: 000000000000000000180080540081E443510088426D85606480C7200041
VCID: 3828D6AB1251A6CB8B0-806C
Subsystem 1 - Part number SW: 3AB 955 419, HW: 3AB 955 419, Label file: DRV\1KX-955-119.CLB.
Part number: Wiper 08111 10 0603.
Encoding: 00B795
Subsystem 2 - Part number: 1K0 955 559 AH
Label file: DRV\1K0-955-559-AG.CLB
Component: RLS 171110 05 54 0403
Encoding: 033028
3 error codes found:
00447 - Function impairment due to overvoltage.
001 - Upper limit exceeded - Intermittent.
Error status: 00100001
Error priority: 6
Error frequency: 9
Lost Count: 30
Mileage: 204,273 km
Time: 0.
Date: 2020.11.05
Time: 11:27:19
Class 15, entry.
Voltage: 14.75 V
one
one
one
text
from
one
01504 - License plate illumination (X)
010 - Intermittent interruption/short circuit after the positive terminal - Occasional.
Error status: 00101010
Error priority: 2
Error frequency: 17
Lost Count: 33
Mileage: 206,212 km
Time: 0.
Date: 2021-01-30
Time: 11:51:30
Class 15, OUT.
Voltage: 12.05 V
text
from
one
text
from
text
from
text
from
02739 - Lamp for brake and tail light, right side.
Error priority: 1.
Error frequency: 1.
Lost Count: 17
Mileage: 206,226 km
Time: 0.
Date: 2021-01-31
Time: 11:01:24
Class 15, entry.
Voltage: 14.30 V
one
one
one
text
from
one
Address 10: Parking Assist 2 (J446) Label file: | DRV\3AE-919-475.clb
Part number SW: 3AE 919 475, HW: 7N0 919 475.
Component: PARKING ASSIST 8K H04 0009.
Revision: -------- Serial Number: 77631033400042
Encoding: 108002
Operating number: WSC 99999 1023 2097151.
ASAM Dataset: EV_EPHVA18VW47X0000 001003
ROD: EV_EPHVA18VW47X0000.rod
VCID: 7CA00ABB66694AEB2F8-8028
Address 15: Airbag
Label file: DRV\5N0-959-655.lbl
Part number SW: 5N0 959 655 R. Hardware: 5N0 959 655 R.
Part number: J234__101 VW10 HI 1918
Revision: 22014000 Serial number: 003K0PPED8E-
Encoding: 0012337
VCID: 4CC09A7B7AC93A6BDF8-8018
Subsystem 1 - Serial number: 6332MTS654973060.
Subsystem 2 - Serial number: 6342MTS634583070.
Subsystem 3 - Serial number: 6351HTS66BUTH9KJ
Subsystem 4 - Serial number: 6361HTS6JE7RE6KR
Subsystem 5 - Serial number: 0000000000000000.
Subsystem 6 - Serial number: 0000000000000000.
Address 16: Steering wheel electronics (J527)
Label file: | DRV\3C0-953-569.clb
Part number SW: 3C9 953 501 BN, HW: 5K0 953 569 AB.
Component: STEERING MODULE 009 0136
Revision: FF010039 Serial Number: 20101128301092
Encoding: 118A250000
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 76B41893584510BB59C-8022
Control unit for multifunction steering wheel:
Subsystem 1 - Part number SW: 3C8 959 537 D, HW: 3C8 959 537 D, Label file: DRV\3C8-959-537.CLB.
Component: E221__MFL-TK6 H06 0022
Encoding: E20000
Address 17: Control panel module (J285)
Label file: | DRV\3C8-920-xxx-17.clb-SRI1
Part number SW: 3AA 920 870 A, Hardware: 3AA 920 870 A.
Component: COMBINATION H20 0420
Encoding: 161B00
Operating number: WSC 05314 115 12345
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 3038EE8BFAA17E8BC30-8064
Address 19: Diagnostic interface (J533)
Label file: .DRV\7N0-907-530-V2.clb
Part number SW: 7N0 907 530 G, HW: 1K0 907 951.
Component: J533 Gateway H41 1614.
Revision: H41 Serial Number: 261110F1001107
Coding: 462006
Operating number: WSC 05314 000 00000
VCID: 3430E29B0E3942ABA78-8060
Address 25: Immobilizer
Label file: DRV\3C0-959-433-25.clb
Part number SW: 3AA 959 433 HW: 3AA 959 433
Component: IMMO 043 0399
Revision: 00043000 Serial Number: VWZCZ000000000
Operating number: WSC 131071 1023 2097151.
VCID: 76B4189354C510BB59C-8022
Subsystem 1 - Part number: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 37: Navigation (J794)
Label file: | DRV\1K0-035-27x-37.clb
Part number SW: 3C0 035 279, HW: 3C0 035 279.
Component: RNS315 H05 0010
Serial number: VWZAZ2K8346356
Encoding: 000004310400000000011000
ASAM Dataset: EV_RNS315VWEUV1UDS A01005
ROD: EV_RNS315VWEUV1UDS.rod
VCID: 60985ECBEAC18E0B130-8034
Address 42: Door Electric Driver (J386) Label file: | DRV\3C0-959-70X-GEN4.clb
Part number SW: 3AA 959 701 A, HW: 3C0 959 793 C.
Component: DOOR-SG FT 002 0529
Revision: 12110009 Serial Number: 0001826747
Encoding: 0200B7
Operating number: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 3536DF9F05C35BA3906-8060
Slave Driver:
Subsystem 1 - Part number SW: 3C0 959 703 HW: 3C0 959 795 Label file: DRV\1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0407
Serial number: 00000001778112
Encoding: 000090
Address 44: Steering Assist
Label file: DRV\5N1-909-144.clb
Part number SW: 5N1 909 144 L, HW: 5N1 909 148 G.
Component: J500__APA-BS Class 309 0802
Revision: 1AH03729 Serial Number: 00103270063701
Coding: 0000258
VCID: 3B22C9A72F678DD3662-806E
Address 46: Comfort System; Label file: .DRV\3C0-959-433-46.clb
Component: KSG PQ47 ELV 043 0631
Encoding: 0191020052830E76300494157C084FCE707C01
Subsystem 1 - Part number: 1K8 951 605 A
Part: LIN BACKUP HORN H11 9004
Subsystem 2 - Part number: 3C0 951 171 C
Component: Tilt sensor 004 0611
Subsystem 3 - Part number: 3C0 951 171 C
Component: Interior monitoring system 004 0611.
"One error found:"
01134 - Siren (H12)
text
000 - -
Error status: 01100000
Error priority: 4.
Error frequency: 5
Lost Count: 237
Mileage: 204,135 km
Time: 0.
Date: 2020.10.12
Time: 15:51:12
Address 4F: Central Electricity II (J520)
Label file: .DRV\1K0-907-532.clb
Part number SW: 7N0 907 532, HW: 1K0 907 951.
Component: EZE_2 H41 1614
Encoding: 00000008
VCID: 6FBA2DF7279F21739AA-803A
Subsystem 1 - Part number: Software: 3AA 919 204, Hardware: 3AA 919 204.
Component: Analog clock 003 0003
Address 52: Power door lock, front passenger side (J387) Label file: | DRV\3C0-959-70X-GEN4.clb
Part number SW: 3AA 959 702 A, HW: 3C0 959 792 C.
Component: DOOR-SG BT 002 0529
Revision: 14110009 Serial Number: 0001842622
Encoding: 0200B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 3634D89318C550BB99C-8062
Slave Passenger:
Subsystem 1 - Part number SW: 3C0 959 704 HW: 3C0 959 794 Label file: DRV\1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0407
Serial number: 00000001791482
Encoding: 000090
Address 53: Parking brake
Label file: DRV\3AA-907-801.clb
Part number SW: 3AA 907 801 E, HW: 3AA 907 801 E.
Part number: J540 EPB4 VW-55183 0007
Revision: H18 Serial Number: 00000000060150
Coding: 0022067
VCID: 3332E18707374593BE2-8066
Address 61: Battery Management (J840) Label file: .DRV\1K0-907-534.clb
Part number SW: 7N0 907 534, HW: 1K0 907 951.
Component: Battery management system H41 1614.
Serial number: 261110F1001107
Encoding: 030B185A
VCID: 71BE2B8F31AB37838CE-8024
Subsystem 1 - Part number SW: 1K0 915 181 F, HW: 1K0 915 181 A.
Component: J367-BDM H07 0150
Serial number: 00000000009370207906
Address 77: Phone (J412)
Label file: | DRV\7P6-035-730.clb
Part number SW: 7P6 035 730 D, Hardware part number: 7P6 035 730 D.
Component: TELEPHONE H05 0440
Revision: 1B001001 Serial Number: 00007668969448
Encoding: 0A00000000000001
ASAM Dataset: UHVNA A01007
ROD: UHVNA.rod
VCID: 3332E1870BB74593BE2-8066
Two error codes found:
9457425 - Left audio channel for voice/telephone.
B104F 11 [001] - Short circuit to ground.
Unconfirmed - checked since last deletion.
9457169 - Right audio channel for voice/telephone.
B104E 11 [001] - Short circuit to ground.
End -------- (Duration: 01:41, Battery voltage start/end: 12.4V/12.4V) ---------
