USB-Interface wird nicht erkannt | Posts 16+
Go to page: Previous  1, 2
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
jeepmatt1
dieselschrauber likes this.
Post29-03-2021, 20:56    Subject: Quote
Hello Rainer, after investigating the Windows 10 dialog boxes, I now see in the Device Manager that the HEX-USB driver was actually not installed or updated. Whatever the reason...
I searched for drivers on the PC, installed them, and now the interface has been recognized! icon_biggrin.gif
Tomorrow, I'm going to the car. Should probably work now.
will report.
Thank you for the input; sometimes it can feel a bit silly when it turns out that the whole issue was just due to a small detail.
...I found myself better suited to XP...
Greetings from Ticino, Matteo
 File size:  16.58 KB
 Viewed:  2345 times
VW Lupo 3L, 2002
Daihatsu Copen 660 Turbo, 2004
Mitsubishi Pajero V20 2800 TD, 1997
VW T3 Doka 2,1 WBX, 1986
Mercedes 300 TE 4matic, 1991
Post29-03-2021, 23:50    Subject: Quote
Thank you for the feedback! Please ensure that the interface is not plugged in during the VCDS software installation. icon_wink.gif
jeepmatt1
Post30-03-2021, 20:29    Subject: Quote
icon_smile_thumb_up.gif icon_smile_thumb_up.gif icon_smile_thumb_up.gif icon_smile_thumb_up.gif
everything is working as expected. I can no longer be certain whether the interface was connected during installation, but it is certainly possible that it was.
Thank you again, now we will proceed with troubleshooting.
Best regards, Matteo
VW Lupo 3L, 2002
vag-driver
Post30-05-2021, 0:38    Subject: Quote
Today I experienced the same problem on Windows 10. Interface not recognized.
I had to install the driver from the Ross-Tech directory.
Andreas
Post31-05-2021, 16:58    Subject: Quote
The VCDS installation package and the additional software in the customer account have been updated!
https://shop.dieselschrauber.org/en/account.php
Alternatively, directly to the VCDS Installation Package:
https://shop.dieselschrauber.org/en/support-downloads.php
Feedback is welcome, as I only have a limited selection of Windows versions to test.
Best regards, Rainer
Florian320
2004 Audi Cabriolet
Post27-06-2021, 13:50    Subject: Quote
Small update from me: After reinstalling the latest VCDS version on a new computer, I also had the problem that the driver was missing, and therefore the HEX-CAN USB was not recognized.
After manually updating the driver from the above directory, it worked immediately.
Post01-07-2021, 19:18    Subject: Quote
The installation package has been updated again; it seems there was a bug in the driver installation for older interfaces. icon_idea.gif
gtone
Post02-06-2026, 12:59    Subject: Same problem Quote
Hello everyone,
Unfortunately, I need to bump this post, as I'm now experiencing the same problem after updating to version 26.3.0. The interface is not found. The USB library version 03.02.07 does not seem to have a solution. The Device Manager is not working with it. Hex-USB + CAN Windows 11
Post02-06-2026, 13:36    Subject: Re: Same Problem Quote
gtone wrote:
Hello everyone,
In the "Tree Menu" installation, install the "Legacy Drivers". These are normally disabled because they are no longer produced since 10 years.
Latest VCDS 26.3 from customer account, does the installation work otherwise?
Hi, Rainer
gtone
Oti likes this.
Post03-06-2026, 19:55    Subject: Quote
Thank you in advance for the response, I believe the legacy drivers are missing in the latest version, is that possible?
 Screenshot 1
 File size:  34.92 KB
 Viewed:  131 times
No new posts Reducer flow not detected Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VW Crafter: Second battery not charging Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: HEX-USB CAN adapter not found after update General Tips
No new posts Steuergerät wird nicht mehr erkannt Diesel Engine Technology
No new posts Probleme mit hinteren Türen, Öffnung wird nicht erkannt. On-Board Diagnostics (OBD)
No new posts What interface is required On-Board Diagnostics (OBD)
No new posts Ross-Tech USB interface not found! On-Board Diagnostics (OBD)
