Pasi_222
18-09-2022, 19:29 Subject: P1855 Software Status Monitoring Sporadically |
Hey everyone, I'm new here on the forum.
I have a Passat 3BG 1.9 TDI with the Avf engine. I recently replaced the ABS control unit, exactly the same as my old one, and I coded it using the same method as I used with my old one, so all the data is exactly the same. He has identified the control unit, but when I perform a car scan, the error codes P1855 and P1649 appear. I would like to know why these error codes are now being stored in the memory. I would appreciate a response.
Best regards, Florian
guste100 Profi-Schrauber
Joined: 07/27/2004 Posts: 2402 Karma: +440 / -0 Location: Mitte Schleswig Holsteins 2007 Volkswagen Passat Premium Support
dieselschrauber likes this. |
19-09-2022, 12:36 Subject: P1855 Software Status Monitoring Sporadically |
Please set up the complete car scan here.
Profile PM Garage |
Pasi_222
19-09-2022, 22:46 Subject: P1855 Software Status Monitoring Sporadically |
"The scan of the steering angle sensor is already complete, but the other 2 are still throwing errors into the fault memory."
| Description: |
| File size: |
5.71 MB |
| Viewed: |
3290 times |
20-09-2022, 8:23 Subject: P1855 Software Status Monitoring Sporadically |
guste100 wrote: | | Please set up the complete Auto Scan here. |
Please save the complete Autoscan as text and post it here. This includes both the detected errors and the dependencies to other control units. It is also possible to check whether you are using a legitimate VCDS or a pirated copy.
Greetings
Guste
Profile PM Garage |
Simon89
Joined: 06/02/2021 Posts: 2 Karma: +0 / -0 Location: Neuenkirchen-Vörden
15-09-2024, 12:03 Subject: P1855 Software Status Monitoring Sporadically |
Hello.
Is there already a solution to the problem?
I'm having the same problem. The error is in the engine control unit, and the ABS control unit cannot be coded despite using ODIS.
Maybe the OP is still active here and has a solution.
Simon
Knox92 Schrauber
Joined: 07/23/2019 Posts: 30 Karma: +22 / -0 Location: Österreich
15-09-2024, 22:51 Subject: P1855 Software Status Monitoring Sporadically |
Do you have a complete scan of the vehicle?
Is the control unit new or a used one that you installed?
Are the part numbers from the control units identical, especially the index at the end, which is often very important?
Best regards!
VCDS, VCP, Fahrzeugdoku & Anleitungen vorhanden
________________________________
Fahrzeuge:
- Golf 5 1.4 BUD 2009
- Touran 1T 1.9 BLS 2011
Simon89
19-09-2024, 10:16 Subject: P1855 Software Status Monitoring Sporadically |
Hello.
Thank you for your response. The scan is attached.
ABS control unit is the original. But it reset itself automatically.
Greetings
| Description: |
 Download |
| File name: |
Log-DIRK-WVWZZZ3BZ2E422490-350890km.txt |
| File size: |
4.41 KB |
| Downloaded: |
189 times |
