Headlight leveling error code 01538
ckone
Post24-03-2006, 19:39    Subject: Headlight leveling error code 01538 Quote
I'm having a problem with my headlights. As soon as I turn on the ignition, they move down and then up, which wasn't happening before.
I installed xenon headlights, and the control unit is displaying error code 01538.
If I delete the error, it reappears immediately.
Can someone tell me what the error is here?
The engines are still working perfectly.
Thank you.
bloesch
Post24-03-2006, 22:37    Subject: Headlight leveling error code 01538 Quote
hi.
There are different systems... some start by going up and down, while others don't.
The error code indicates a problem with one of the motors responsible for closing the LWR (Low Voltage Release).
With a little luck, a new default setting might also help... (but I think there are probably separate error codes for that...)
ckone
Post25-03-2006, 9:49    Subject: Headlight leveling error code 01538 Quote
So, mine usually don't go up and down.
I've already reset the basic settings.
Oh yes, it's also showing '16 00 - Signal out of tolerance'.
bloesch
dieselschrauber likes this.
Post25-03-2006, 11:19    Subject: Headlight leveling error code 01538 Quote
Morning!
Please provide the complete error memory content, including numbers and words.
(This will also indicate whether it's a VW-specific error code or a generic P-code.)
"The error code 1600 seems more like a throttle valve or oxygen sensor issue."
ckone
Post28-03-2006, 16:27    Subject: Headlight leveling error code 01538 Quote
'That's what the error code says.'
01538 Servo motors for headlight range adjustment - V48/V49.
16:00 - Signal out of tolerance.
Pszuechter
Post02-11-2022, 14:33    Subject: Headlight leveling error code 01538 Quote
I'm experiencing the same error. How did you fix it? Sorry for reviving this old thread; I just didn't want to start a new thread with the same title.
The error code scan is attached.
The car is a Golf 5 2.0 TFSI GTI.
PS
 File size:  7.05 MB
 Viewed:  603 times
Post02-11-2022, 17:09    Subject: Headlight leveling error code 01538 Quote
The thread creator is no longer logged in.
No new posts Halogen lamp adjustment, Headlight alignment Technical Articles
No new posts Automatic Headlight Leveling VW Touran 1T Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error code P1351 General Tips
No new posts Headlight Leveling: Automatic Adjustment Transmission, Chassis, Body & Interior
No new posts Audi A6 C6 Headlight Leveling System Electrical Systems, Vehicle Electronics, Multimedia
No new posts Headlight Adjustment Repair: How To Fix? On-Board Diagnostics (OBD)
No new posts Error code Diesel Engine Technology
