Calibrate steering angle sensor G85
New Topic Reply 🔗 ⭐ 🖨 Dieselschrauber - Index » Electrical Systems, Vehicle Electronics, Multimedia
abicim
Post26-02-2021, 14:52    Subject: Calibrate steering angle sensor G85 Quote
Hello everyone,
I have a Golf 5, and the last thing I did was replace the battery. Now, the steering wheel symbol and the ESP symbol are illuminated in yellow on the dashboard. I've tried to reset it using VCDS, following various guides from other users, but I haven't been able to get it to work. I've also tried the Rosstech guide. Can someone please help me?
Thank you in advance.
Translated on 05-07-2026, 20:32.
vag-driver
dieselschrauber likes this.
Post26-02-2021, 14:56    Subject: Calibrate steering angle sensor G85 Quote
Can you tell us what you have already tried?
Andreas
abicim
Post26-02-2021, 15:02    Subject: Calibrate steering angle sensor G85 Quote
... Instructions that didn't work, edited by the administrator...
vag-driver
Post26-02-2021, 15:10    Subject: Calibrate steering angle sensor G85 Quote
Can you provide us with your car's diagnostic scan data?
Andreas
Translated on 05-07-2026, 20:33.
Post26-02-2021, 15:36    Subject: Calibrate steering angle sensor G85 Quote
Have you ever driven longer distances than just 5-10 meters?
In my hazy recollection, single-digit meters don't seem sufficient.
Guste.
Ich_Can_nix
Post26-02-2021, 16:07    Subject: Calibrate steering angle sensor G85 Quote
Generally, after replacing the battery in a Volkswagen Golf 5, a diagnostic tool is not necessarily required to reset the ESP warning light.
Here, simply calibrating the limit switches and running a short distance is sufficient.
Have you tried this, or did you immediately start using the testing tool?
As Andreas already mentioned, a complete car scan would be helpful now.
Have you done anything else to the vehicle, or just disconnected/reconnected the battery?
Has the vehicle been modified?
Possibly. Is a Golf 6 steering wheel installed?
Greetings.
Translated on 05-07-2026, 20:34.
Post26-02-2021, 16:20    Subject: Calibrate steering angle sensor G85 Quote
Hello.
guste100 wrote:
Have you ever ridden for distances longer than just 5-10 meters?
Guste
I would have started by simply driving for 1 kilometer and trying out a few different scenarios, rather than messing around with the control units. Left, right, brakes with ABS activation, etc.
If everything is still glowing afterward, I would have investigated the reason.
"Simply disconnecting the battery" should not cause any issues.
I have deleted your collection of tutorials that didn't work, as such posts cause more problems than they solve. Exactly what one should not do is simply follow random instructions and tinker with control units without knowing what one is doing! icon_idea.gif
Where is your car scan?
Translated on 05-07-2026, 20:36.
Karma: +646 / -0   Thank you, like it!
Post20-04-2023, 6:02    Subject: Calibrate steering angle sensor G85 Quote
Hi.
Yesterday, a friend came by with a Golf 5 Variant, and he's having the same problem: the steering angle sensor cannot be initialized.
I need to access the steering assist control unit through the installed version, checking things like access permissions, basic settings, and channel zero calibration. I can get to that point, but the "Start" button isn't activated, so I can't click it.
There wasn't time for a longer story yesterday.
I can only provide the Autoscan feature once I've had the car for a longer period and have the necessary time to do it properly. However, it's possible I've forgotten something or am simply not smart enough to handle it.
Thank you.
Translated on 05-07-2026, 20:38.
Gremlin
Avatar-Gremlin
Karma: +92 / -0   Thank you, like it!
2000 Audi A4 Avant Consumption
Post23-04-2023, 6:14    Subject: Calibrate steering angle sensor G85 Quote
I just experienced this recently when I installed an AHK (presumably a type of electronic component) on a 2007 model.
Error message G81, steering angle sensor.
- Steering adjustments to both sides (while the engine is running) had no effect.
-Driven for a short distance, approximately 20 meters, and the error disappeared icon_smile_thumb_up.gif.
Translated on 05-07-2026, 20:39.
Post23-04-2023, 7:07    Subject: Calibrate steering angle sensor G85 Quote
Thanks for the feedback, but unfortunately, nothing here seems to help. There's a different issue at play. I'll be running an Autoscan soon, and I'll create a new thread about this topic.
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Documentary: Programming VW car keys from 1998 onwards Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Audi A3 8P Steering Angle Sensor G85 Electrical Systems, Vehicle Electronics, Multimedia
No new posts Steering Angle Sensor VW Polo 9N On-Board Diagnostics (OBD)
No new posts Steering Angle Sensor Calibration Issues On-Board Diagnostics (OBD)
No new posts Steering Angle Sensor Golf 4: Location & Installation On-Board Diagnostics (OBD)
