Polo 6N Heater Core / Heat Exchanger
vag-driver
Post05-06-2023, 11:10    Subject: Polo 6N Heater Core / Heat Exchanger Quote
A connector is broken, so I have taken the WT (water turbine) out of operation to prevent coolant loss.
Unfortunately, to replace the water temperature sensor, the dashboard and the entire blower motor assembly must be removed. This is quite a significant amount of work.
Now I'm thinking about gluing a new piece onto the broken connection.
Does anyone have experience with this type of adhesive?
Andreas
Translated on 29-10-2026, 15:41.
E30_V8
Karma: +111 / -0   Thank you, like it!
2005 Skoda Fabia Consumption
dieselschrauber likes this.
Post05-06-2023, 22:17    Subject: Polo 6N Heater Core / Heat Exchanger Quote
It depends on what the damaged area looks like. Is it just a crack? Where exactly is it broken? Does it just need to be sealed without any mechanical stress?
Approximately 1.5 bar of pressure in the cooling system already requires a certain level of structural integrity.
If it's one of the plastic pipes in front of the oval plate (from the engine compartment, where the hoses connect), you could try adding a suitable brass pipe as well.
to be glued in as an "internal support sleeve" using, for example, Sikaflex 221, to provide stability.
Is it a cleanly broken piece? I see the problem lies in the connection between the plastic and the adhesive; the adhesive would need to be able to "melt" the plastic slightly in order to create a proper and durable bond.
I have also repaired less stressed parts made of ABS or PP using a soldering iron, but it's crucial not to inhale the fumes that are produced during the process!
If the damage extends to the side of the water tank, there is little chance of repairing it without removing the tank.
Good night.
Best regards, Richard.
Polo V 1,6 Tdi (CAY)
Translated on 29-10-2026, 15:42.
E30_V8 likes this.
Post06-06-2023, 6:07    Subject: Polo 6N Heater Core / Heat Exchanger Quote
Many years ago, the connection fitting between the radiator and the expansion tank broke off on my Passat. The side pieces and the connection fitting were made of plastic.
I then generously glued a brass tube in place using a two-part adhesive.
That earned me the nickname "world's greatest radiator fixer" from my fellow students, but I simply didn't have the money for a new radiator. icon_biggrin.gif
1.5 years later, the car was disposed of for other reasons, and the radiator was still intact.
So, if you can get it to fit reasonably well and fix the connection in a way that minimizes mechanical stress (I simply inserted the tube as far as it would go and it rested in a recess on the back), I would say it's worth a try.
Translated on 29-10-2026, 15:45.
vag-driver
Post06-06-2023, 8:29    Subject: SEO: Best German to English Translation Services Quote
Thank you for your responses.
Indeed, the inlet nozzle has broken off due to material fatigue. The connection looks quite worn. There's still about 1 cm of it remaining before the injection molding wall.
Since I still have another identical Polo that I use for parts, I've decided to use its heat exchanger. While it's the same age, it has only been used for 180,000 km, whereas the broken one had 440,000 km on it.
I think that should be enough for 2.5 years.
Andreas
Translated on 29-10-2026, 15:46.
Karma: +645 / -0   Thank you, like it!
dieselschrauber, Turbinchen and E30_V8 likes this.
Post08-06-2023, 7:11    Subject: Polo 6N Heater Core / Heat Exchanger Quote
If you're already going to the trouble of removing the dashboard, you should definitely have the 30 euros for a new heater core.
Translated on 29-10-2026, 15:47.
E30_V8 likes this.
Post08-06-2023, 11:13    Subject: Polo 6N Heater Core / Heat Exchanger Quote
Rüdi wrote:
If you're going to the trouble of removing the dashboard, you should definitely have the 30 euros for a new heater core.
Most likely, the old, used heat exchanger will break during installation. icon_cool.gif
Translated on 29-10-2026, 15:48.
vag-driver
Post08-06-2023, 11:39    Subject: Polo 6N Heater Core / Heat Exchanger Quote
The price at the counter is 250€.
BTW: The car should last for another 2.5 years. After that, hopefully, the situation in the used car market will be more normal again.
Andreas
Translated on 29-10-2026, 15:49.
Post08-06-2023, 18:55    Subject: Polo 6N Heater Core / Heat Exchanger Translating...
[Translating...]
https://www.daparto.de/Teilenummernsuche/Valeo/812030?modelId=e27fae31
Post08-06-2023, 20:07    Subject: Polo 6N Heater Core / Heat Exchanger Translating...
[Translating...]
Post08-06-2023, 20:10    Subject: Polo 6N Heater Core / Heat Exchanger Quote
And that's not cheap garbage...
vag-driver
Post08-06-2023, 21:43    Subject: Polo 6N Heater Core / Heat Exchanger Quote
Also, I always check daparto. That's why I had to laugh so much about the VW price. icon_smile_thumb_up.gif icon_lol.gif
Andreas
Post09-06-2023, 5:11    Subject: Polo 6N Heater Core / Heat Exchanger Quote
And yet, you still want to install the used one?
vag-driver
Post14-06-2023, 21:07    Subject: Polo 6N Heater Core / Heat Exchanger Quote
Probably. I need to take a closer look. The heat seems to be affecting the plastic more than the age of the device. At least, that's my impression when I look at the connectors.
Andreas
Translated on 29-10-2026, 15:50.
Post15-06-2023, 5:40    Subject: Polo 6N Heater Core / Heat Exchanger Quote
Both have problems... When buying new, the brand is the only important factor.
I'll be seeing it at the Galaxy soon... X
No new posts Polo 86c 40 kW, year 1992, 1272 ccm, AAV throttle potenti... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Polo 9N: Vibration Problems & Solutions Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Heat Exchanger A3 8L: Supply & Return Transmission, Chassis, Body & Interior
No new posts Oil-Water Heat Exchanger Retrofit, MKB AGR Diesel Engine Technology
No new posts Removing the heat exchanger, Golf III Transmission, Chassis, Body & Interior
No new posts Oil-Water Heat Exchanger Retrofit Diesel Engine Technology
