Rear brake caliper, sequence
Karma: +591 / -0   Thank you, like it!
Post15-08-2023, 18:27    Subject: Rear brake caliper, sequence Quote
Hello!
Actually, it's an old topic.
I need to borrow a Ford Focus from a friend; it's 10 years old.
Replace a brake caliper from the rear.
Because the edge under the cuff is oxidized, leaky, and already somewhat corroded.
It's still that design where the handbrake cable connects to the brake caliper.
I don't remember anymore; it's been too long. The usual procedure was actually to bleed the brakes first, then pump the pressure until the pads engage.
And finally, the handbrake cable is attached. That's how I remember it.
Everyone does it differently; the workshop next door told me the same thing, that it doesn't matter.
Now, a bracket is attached to the new brake caliper for the handbrake cable.
"CAUTION!!!"
DO NOT operate the lever before [insert condition/time].
"Fitting and applying pressure!"
I cannot translate that correctly.
My phone's text translator keeps giving me different translations all the time.
You surely have a tip for me, right?
so that I can assemble it properly tomorrow?
Turbinchen
Karma: +75 / -0   Thank you, like it!
2014 Audi A4 Avant
dieselschrauber, Rüdi, Steffen G and E30_V8 likes this.
Post15-08-2023, 18:32    Subject: Rear brake caliper, sequence Quote
Literally translated, the lever for the cable should not be moved before the caliper is mounted and bled, meaning that brake pressure has been established.
Exactly as you remember it. After that, in my opinion, the ropes should also be readjusted.
dieselschrauber likes this.
Post15-08-2023, 20:31    Subject: Rear brake caliper, sequence Quote
Hi!
Yes, thank you.
I'll do that tomorrow, then.
I'll check the brake cables and see if it's necessary.
No new posts Spark plug firing order Technical Data
No new posts Golf 1J: Rear Clicking Noise - Diagnosis & Repair Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Workshop action Polo MJ 2000, rear brake hose Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Rear Brake Caliper: Sticking Handbrake Mechanism Transmission, Chassis, Body & Interior
No new posts Golf 5 2.0 TDI 4-Motion rear brake caliper Transmission, Chassis, Body & Interior
No new posts Change MFA Display Order Levels On-Board Diagnostics (OBD)
No new posts Error: Incorrect Request Order - Fix Now! Diesel Engine Technology
