Driver issue during VCDS reinstallation
Heiner111
Karma: +27 / -0   Thank you, like it!
Post27-10-2025, 18:59    Subject: Driver issue during VCDS reinstallation Quote
Hello, after a long and unsuccessful search, I finally have to write here. I had to install VCDS on my new laptop (WIN11), and I have a HEX-USB+CAN interface.
I installed the latest version, and it ended with the message "Driver cannot be loaded on this device." Under "more information," I learned that I need to disable memory integrity under "core isolation." I did that, restarted, and reinstalled, but it's still the same. The driver isn't clearly displayed in Device Manager; according to the description here, it should be located under "Input Devices." I assume it's the entry at the bottom labeled "Input Device" without a more specific name. At least, that's what I tried to update, specifying "Rosstech" as the folder. And I received a message saying that I already had the best version.
Now, after the 3rd attempt, this driver is no longer displayed in the Device Manager, even though I hadn't manually removed it before. The memory integrity feature is still disabled.
I've also noticed that the error window lists "RT-USB64.sys" as the driver (not a *.inf file, as is usually the case with drivers). According to my research, this driver is only for older hardware. As a possible solution, I've seen it suggested to check the box that says "...older drivers" (or "legacy drivers"). I don't have that option available to me anymore.
Oh yes, the connection test isn't working, probably due to a lack of drivers. The green LED on the interface is lit.
"There are probably several HEX-USB+CAN devices running on newer laptops with Windows 11." How did you solve it?
Andreas.
Post28-10-2025, 9:42    Subject: Driver issue during VCDS reinstallation Quote
You seem to have already found the HEX-USB+CAN driver problem for Windows 11.
Is your antivirus software not detecting anything either?
What processor platform do you have for Windows 11? Could you please post a Screenshot of your Windows system information?
Before we begin: There are no HEX-USB+CAN drivers for Windows on ARM, simply because they didn't exist back then. X86 and AMD64 are not a problem.
Heiner111
Post28-10-2025, 11:12    Subject: Driver issue during VCDS reinstallation Quote
Good morning, Rainer,
Later, I realized I wanted to add something about the antivirus software. Good question. But it's quite new, so besides Windows Defender, there's nothing else from third-party vendors installed for antivirus. Also, there's almost no other software or specific drivers installed. Besides the Explorer window, nothing else was open during the installation.
The processor should be straightforward and standard, nothing fancy. See below. Image.
I'm not an expert on this, but from my perspective, it's nothing out of the ordinary.
No new posts Brake Bleeding with VCDS: A Complete Guide Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Battery Status with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS: Resetting DSG Transmission Settings Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts VCDS 26.9.0 Update: SFD Now Available in German Version On-Board Diagnostics (OBD)
No new posts VCDS 11.11.5 is outdated, VCDS: Software is outdated On-Board Diagnostics (OBD)
No new posts VCDS-RKS: Version 11.11.2 Update & Features On-Board Diagnostics (OBD)
No new posts VCDS-RKS 12.12.2: Update & Features On-Board Diagnostics (OBD)
