How did you attempt to bleed the brakes? Did you apply pressure to the brake fluid reservoir, or did you use the brake pedal? Was the ignition on or off during the process?
It almost looks like the inlet valve for the brake on the rear left side of the ABS module is blocked. However, this should only happen when the system is activated.
Can you individually address the valves in the ABS module during an actuator diagnosis? If so, do they sound the same?
Don't forget to run the
Autoscan!
