Task: Target Passat GTE - J743 and lift CP
Ste.Bo
Karma: +90 / -0   Thank you, like it!
dieselschrauber likes this.
Post07-06-2025, 20:48    Subject: Task: Target Passat GTE - J743 and lift CP Quote
Hello everyone,
My journey with the Passat is hopefully coming to an end.
After the gearbox control unit of a similar donor vehicle was installed, the car is no longer exhibiting any unusual behavior. The engine starts successfully every time, and in electric mode, it always displays "Ready".
Because the donor vehicle was 6 months younger, the ECU had an increment higher for both the SW number and the data set compared to my original. E -> F
021 -> 022
Therefore, my VW dealership wants to make no changes to the car. However, they at least provided me with the logs from the ODIS session. So that I can see that it would not be a problem to carry out the inspection of the construction state and to install the correct SW on the gearbox.
Unfortunately, the TCU swap also worked as expected, completely disabling component protection... and that's across the entire system (see Appendix)!
Therefore, if someone is officially authorized with ODIS and the corresponding rights (GeKO/SVM) and is located in the Alb-Bodensee region, they can raise their hand or send me a private message (PN). Then we'll clarify money and time.
Thank you and best regards.
Bo
 File size:  107.55 KB
 Viewed:  1203 times
Ste.Bo
Post10-06-2025, 15:50    Subject: Task: Target Passat GTE - J743 and lift CP Quote
Can anyone recommend someone who does this?
Hello
Bo
Karma: +802 / -0   Thank you, like it!
Post17-06-2025, 21:37    Subject: Task: Target Passat GTE - J743 and lift CP Quote
Ste.Bo wrote:
Could anyone perhaps recommend someone who does this?
Hello
Bo
Not a recommendation, but have you already inquired with chip tuners and radio installers in your area?
Ste.Bo
Post17-06-2025, 23:09    Subject: Task: Target Passat GTE - J743 and lift CP Quote
Yes, clone all of them in an assembled state, and my mechatronics are already installed. But I want the newer building with up-to-date software that doesn't damage gearboxes anymore. icon_biggrin.gif
Ste.Bo
Post02-12-2025, 1:11    Subject: Task: Target Passat GTE - J743 and lift CP Quote
VW rejected the request for used parts in the summer. I had to clone the old control unit to the "new" one.
It's been running smoothly ever since, and Dad is happy again.
Post02-12-2025, 9:38    Subject: Task: Target Passat GTE - J743 and lift CP Quote
Mutley1975
Post22-10-2026, 15:18    Subject: DQ400 mechatronic testing Quote
Hi there, sorry if this is slightly off topic o saw a very interesting post by STE Bo about flushing the internal filers in a mechatronic but being a new member couldn’t post there or pm. I have the mechatronic out of the car it builds pressure but after about 4 seconds of pump off it’s back to 43 bar causing the pump to run again. I’ve got a new accumulator but while it’s out was hoping to find a way to vacuum test the oil ways to check for leaks.
Thanks James
Ste.Bo
Post22-10-2026, 15:38    Subject: DQ400 Mechatronic Testing: Solutions & Services Quote
Mutley1975 wrote:
Hi there, sorry if this is slightly off topic. I saw a very interesting post by STE Bo about flushing the internal filters in a mechatronic, but being a new member, I couldn’t post there or send a private message. I have the mechatronic out of the car. It builds pressure, but after about 4 seconds of the pump being off, it’s back to 43 bar, causing the pump to run again. I’ve got a new accumulator, but while it’s out, I was hoping to find a way to vacuum test the oil ways to check for leaks.
Thanks James
What I described was a filter that was clogged with residue from clutch abrasion. Flushing doesn't help. If the filter is clogged, the pressure doesn't build up to the specified values within the specified time, and the pump activation is aborted.
What you are describing points to a leakage within the mechatronics itself (which is unusual/unlikely), a damaged actuator gasket, or most likely a leakage within the gearbox itself (either the slave cylinder or the shaft).
Translated on 22-10-2026, 15:39.
Mutley1975
Post22-10-2026, 16:45    Subject: Task: Target Passat GTE - J743 and lift CP Quote
Thanks for that it was initially struggling to build pressure getting to about 14 - 17 bar I did a fluid change as it was overdue after that it built the pressure but dropped back to 43 after 4 secs. AI suggested it may be the accumulator is broken so it can’t store enough pressure. So I have a replacement to try but while it’s out I was hoping to test if there is any leaks I’m now suspecting debris in the non return valves but can’t find enough information about the mechanic to know the internal path ways to be able to test.
No new posts Passat V157: How to Replace and Calibrate CBDC Module Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Steering Angle Sensor: How to Recalibrate? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Train T90 / T 91 with VCDS Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Passat 3c key programming On-Board Diagnostics (OBD)
No new posts Passat 3C Remote Key Fob Programming - Old Key On-Board Diagnostics (OBD)
No new posts Used Passat 3C Key Programming (2010) Transmission, Chassis, Body & Interior
No new posts Radiocode aufheben oder verstellen Transmission, Chassis, Body & Interior
