Opels super Diesel | Posts 32+
Go to page: Previous  1, 2, 3
Cord
Post11-02-2004, 20:52    Subject: Quote
Here's a link about register loading.
http://www.3k-warner.de/de/products/t_r2s.asp
Translated on 13-10-2026, 19:28.
christians
Post11-02-2004, 20:53    Subject: Quote
Currently, BMW is promoting a design created from a variety of form elements, but only because some idiot forgot to remove the camouflage covering before the premiere of the 7-series icon_biggrin.gif.
Gruß Christian
Translated on 13-10-2026, 19:29.
chris11
Karma: +3 / -1   Thank you, like it!
Post17-02-2004, 14:50    Subject: Quote
BMW is serious about it. See http://www.auto-motor-sport.de/d/53580/d_ams_news_special_ha.
Christian.
HP
Post17-02-2004, 19:01    Subject: Common Rail: Technology, Benefits & Applications Quote
Fiat invented the common rail system, which is something I find amusing.
I work for a diesel engine company that has been experimenting with common rail technology since 1975.
Best regards, HP.
Translated on 13-10-2026, 19:30.
Thomas K.
Post17-02-2004, 20:30    Subject: Quote
Fiat actually developed the common rail system for diesel engines together with Bosch and was the first to bring it into series production. However, they only developed the injection system together with Bosch, not the engine itself. This means that not all common rail diesel engines are based on the Fiat engine.
konjoy
Post18-02-2004, 10:07    Subject: Quote
Fiat actually built the first common-rail diesel engines. And all common-rail diesels produced by Italian and French manufacturers are identical. You can use the same power box for all 1.9 and 2.4 JTD engines (Fiat, Alfa), or dci engines (Renault), or HDI engines (Peugeot).
The 2.5 diesel engine in the Opel Omegas isn't the only BMW diesel used in Opel cars; the 1.7-liter engine with 82 hp is also from BMW, specifically from the 318tds. However, it would have been better if Opel had developed their own engines instead of relying on BMW's. I owned a BMW 525tds, and it was not a pleasant experience. The only good thing about the engine was its smoothness. The fuel consumption was rarely below 10 liters. In the city, it was always over 10 liters. And reliability was definitely an issue. If you managed to reach 200,000 km with the original cylinder head, you were lucky. Either the cylinder head or the cylinder head gasket would fail. In my case, it was the cylinder head, the fuel injection pump, and many other small parts that were very expensive. In the end, a 525i is a more cost-effective option! And finally, the engine wasn't particularly fast! Compared to modern engines, it was very sluggish. 143 hp at 4800 rpm! The engine was very high-revving, which may explain the frequent failures.
Translated on 13-10-2026, 19:32.
Thomas K.
Post18-02-2004, 10:22    Subject: Quote
That's not quite right.
The Peugeot 2.0 HDI CR diesel engines are Peugeot's own designs and have absolutely nothing to do with Fiat engines.
Similarly, the Renault engines are in-house designs.
In some joint development projects (like the Peugeot 807 and Fiat Ulyssee, for example), the companies naturally exchange engines with each other.
The fact that the power boxes can be used in multiple models is simply due to the same common-rail injection system. The power boxes may not differ in their physical construction, but they do differ in their programming.
The 1.7 diesel engine from Opel is actually not from BMW, but from Isuzu.
Translated on 13-10-2026, 19:34.
No new posts Diesel vs. Gasoline: Cost Comparison Technical Articles
No new posts The fine particulate matter disaster and diesel engines w... Technical Articles
No new posts DPF-Diesel and GSKs, Glow Plug Failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Bremsscheiben: ATE Powerdisk im Regen - Top! Transmission, Chassis, Body & Interior
No new posts Diesel 2.0 170 HP: Specs & Performance Diesel Engine Technology
No new posts LD Log A3 8P 2.0 CR Diesel Upload
No new posts Marine Diesel Conversions: SDI Systems On-Board Diagnostics (OBD)
