ladedruckregelventil klickert nach abstellen-agr abgesteckt | Posts 16+
Go to page: Previous  1, 2
Post23-02-2004, 13:53    Subject: Quote
At Wurst.
What kind of engine is it? (It CANNOT be a 1Z, AHU, or any other engine with a wastegate!)
Hey Micha (but you have a 1Z, right?)
What is an engine control unit (ECU)? Does it click when the engine is running? Placing your hand on it is the official VW test!
Translated on 10-10-2026, 11:01.
Wurstblinker
Post23-02-2004, 15:16    Subject: Quote
@ Diesel
The Audi 80 TDI was only available with the 1Z engine.
Let me see if this thing also makes a ticking sound while the engine is running. Unfortunately, the engine is so loud that it will be difficult to figure out.
'MFG' is an abbreviation for 'Mit freundlichen Grüßen,' which means 'Sincerely' or 'Best regards' in English.
Translated on 10-10-2026, 11:02.
MichaB.
Post23-02-2004, 15:53    Subject: Quote
@martin:
It doesn't tick when the engine is idling (1000 RPM), but it does immediately when I turn on the ignition.
Putting your hand on it works great icon_lol.gif. You can definitely feel it in your hand... otherwise, the motor would be too loud to hear it.
'When I was installing the engine, I had a different engine control unit (ECU) available. However, it had SMD sockets (not the familiar EEPROM sockets), so I decided to choose a different ECU.'
Hi Micha,
Translated on 10-10-2026, 11:03.
Post23-02-2004, 17:46    Subject: Quote
@ Sausage
ok, you got a 1Z.
So, the valve regulates the applied boost pressure and "mixes" it with ambient pressure to reduce it.
When you turn off the engine, the N109 sensor doesn't provide a positive signal, and the control unit is also deactivated, meaning the N75 sensor is completely electrically inactive.
Because the turbo is also stationary, normal pressure is present at ALL three connections, so there can't be any mechanical issues. (This is different from the AFN engine, which has a vacuum reservoir, and in this case, the N75 valve is connected to it.)
A 1Z engine cannot rattle with the N75 valve after the engine is turned off.
Translated on 10-10-2026, 11:04.
christians
Post23-02-2004, 20:15    Subject: Quote
dieselmartin wrote:
Because the turbo is also stationary, normal pressure is present at ALL three connections, so there can't be any mechanical issues. (This is different with the AFN engine, which has a vacuum reservoir, and the N75 valve is connected to it.)
A 1Z engine cannot rattle with the N75 valve after the engine is turned off !!!
That's why, as I mentioned, I suspect the AGR valve, regardless of whether it's receiving power or not, is causing the vacuum to drop due to the rattling sound.
Translated on 10-10-2026, 11:06.
MichaB.
Post25-02-2004, 8:09    Subject: Quote
@martin:
I also have a 1Z engine. Is this extreme ticking noise normal? And if the engine is idling, does the ticking stop? All the hoses are connected.
Hi Micha,
Translated on 10-10-2026, 11:07.
Post25-02-2004, 8:32    Subject: Quote
@ Micha
I couldn't find an "I" version!
Are you sure it's not ticking anymore when the engine is running?
If that's the case, it won't boost anymore. Then you'll either have very low boost pressure (0.6 bar), or excessively high boost pressure, depending on which position the valve gets stuck in.
Please translate the following text from German to English. Provide ONLY the translation, no explanations.
- Ignition on.
- Feeling the pulse with your hand.
- Just place your hand on it and start (or let it start).
- Is the ticking sound REALLY gone???
If necessary, connect the LEDs in parallel to see the "tickering_wollen" signal (i.e., the control signal).
If the indicator light is on and nothing is happening, the valve is probably broken.
Translated on 10-10-2026, 11:08.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts No error entries, no matter what is being tested! On-Board Diagnostics (OBD)
No new posts Engine Noise When Shutting Off Diesel Engine Technology
No new posts Golf 4 TDI: Strange Noise When Engine Stops Diesel Engine Technology
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
