Adjust Idle Speed AFN - VAG-COM or Resistor
Arne
Post30-07-2002, 9:54    Subject: Adjust Idle Speed AFN - VAG-COM or Resistor Quote
hi everyone,
I would like to increase my idle speed by approximately 50-60 RPM.
You know I have the AFN engine in my Corrado. And it vibrates a bit at idle. It was designed for diesel engines, after all. But if I just slightly press the accelerator and bring the engine up to 1000 RPM, everything is fine.
Can I do this with VA.G-Com, or is it simply not possible?
My colleague says directly: The gas pedal is a potentiometer. You need to add a resistor in series. That will raise the signal a bit. No, I understand.
'It has a 6-pin connector on the gas pot. Where am I supposed to do anything?'
Thank you (again) for your kind help icon_biggrin.gif.
arne.
Translated on 09-10-2026, 3:27.
Michael II
Post30-07-2002, 11:27    Subject: Adjust Idle Speed AFN - VAG-COM or Resistor Quote
Try using the adaptation channels. All the information is in the error database.
Tschüss
Michael II
Translated on 09-10-2026, 3:29.
Post30-07-2002, 11:39    Subject: Adjust Idle Speed AFN - VAG-COM or Resistor Quote
See the error database and various forum posts. This can only be resolved through adaptation of the control unit. Keyword: adaptation channels.
Arne
Post30-07-2002, 12:16    Subject: Adjust Idle Speed AFN - VAG-COM or Resistor Quote
Michael's article helped me. I did it during my lunch break... and it was successful.
It's actually quite simple. And now, nothing seems to be working anymore.
Thank you again.
Arne.
Select the engine control unit.
Please log in to channels 1, 3, 4, and 5 using the username '12233'.
Select adaptation.
Select the corresponding channel and change the value (which can only be changed within certain limits).
Example: Channel 1: Since this information indicates to the engine control unit (ECU) how long the valve was open, an increase in the value results in a reduction in the fuel injection quantity.
Example: Channel 2: An increase in value results in a higher idle speed.
Channel 1: Injection amount.
Channel 2: Idle speed.
Channel 3: Air mass.
Channel 4: Injection timing.
Channel 5: Starting amount.
Translated on 09-10-2026, 3:31.
No new posts Error Zünder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts T4 2,5 ACV Ignition Lock or MSTG General Tips
No new posts Passat 3C or Superb 3T emergency unlock Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts LMM: Resistance and Challenges Diesel Engine Technology
No new posts Brake Pedal Noise: Causes and Solutions Transmission, Chassis, Body & Interior
No new posts Airbag Ignition Coil Resistance - VW Golf On-Board Diagnostics (OBD)
No new posts Resistance Wattage Between Pin 4 & 7 (10c) Diesel Engine Technology
