Power steering failure after two attempts at replacing the timing belt?
New Topic Reply 🔗 ⭐ 🖹 Dieselschrauber - Index » Diesel Engine Technology
tom76de
Post11-08-2004, 21:36    Subject: Power steering failure after two attempts at replacing the timing belt? Quote
Hi! I'm starting to get really frustrated with my golf game... Maybe you can give me a tip about what might be causing it?
Over the past 4 months, my Golf IV (TDI with pump injectors, manufactured in March 2001) has been in the workshop a total of 6 times.
The whole trouble started when the workshop (located in the Stuttgart area; those who have experienced similar issues can contact us via email icon_smile.gif) attempted to replace the timing belt and tensioner pulley.
After paying a service bill of over €800 and driving away from the garage, I immediately noticed loud thumping and grinding noises (see also my previous post here).
The next day, I went back. The statement was: 'This is normal and will go away with time. Just drive a few kilometers. Those other noises are just normal 'diesel sounds'.'
After several thousand kilometers, the noise got louder. Another mechanic said: 'That's normal. The tensioner pulley is very tight on these TDI PD engines; the timing belt needs to wear in.'
A thousand kilometers later: 'That could be a tension element. Let's take a look.' So, we spent a full day at the workshop. Picked it up, but nothing had changed.
So, I went back again. This time, they expressed concern and asked me to speak with the service manager. He promised things would improve, but he sent me away for now because there were no available appointments.
Wieder hin, Auto zwei Tage in der Werkstatt. Diagnose: Wasserpumpe lÀuft schrÀg, ausserdem noch ein Spannelement ausgetauscht. Kosten: 130 EUR, der neue Zahnriemen und die Lohnkosten trÀgt der HÀndler (Riemen war falsch montiert). Mein Hinweis, die Wasserpumpe sei vor der Wartung nicht defekt gewesen, wird abgetan: 'Das ist normal, die hÀlt der grossen Spannung bei einem neuen Riemen nicht stand'. Wie passt das zu der Aussage, dass das GerÀusch von selbst weg geht??? Soll man warten, bis das Rad der Wasserpumpe ganz abbricht? JIn any case, I had to pay.
I drove out of the yard, and after barely 100 meters, there was a loud screeching and scraping sound when turning into the next curve while simultaneously accelerating. The noise was extremely loud, and it definitely wasn't present before visiting the workshop! I had to turn back. I waited for over half an hour until the service manager finally agreed to talk to me (another technician refused, saying it was a matter for the boss and should remain that way).
He performed a remote diagnosis, essentially saying that I was probably hearing normal sounds because I was upset. I almost had to force him to listen to the car. He eventually agreed, but declined to do a test drive. His diagnosis, even though the noise isn't audible when the car is stationary: The power steering will likely fail soon, but this happens more often and has nothing to do with the attempts to replace the timing belt.
Seit heute abend heult und schleift es auch, wenn man das Lenkrad nicht anrĂŒhrt. Beim Gasgeben und wegnehmen im Leerlauf quitscht es auch kurz. Ausserdem kann man im Leerlauf das Lenkrad in beide Richtungen voll einschlagen, ohne dass das GerĂ€usch auftritt. Ich hatte mal vor langer Zeit einen Golf II, der hat bei Volleinschlag der Servo ein 'schlĂŒrfendes' GerĂ€usch von sich gegeben, was normal war. AbSurely this can't be the right place, or can it?
Long story short... Has anyone had similar experiences after a timing belt replacement?
My non-expert opinion suggests that the power steering pump is located right next to the timing belt in the engine compartment. Also, the V-belt that drives it must be removed as well. Could this be the reason?
I'm grateful for any advice. I think the workshop is ripping me off...
Cheers,
Tom.
Translated on 21-07-2026, 7:06.
D. Kurz
Post11-08-2004, 23:19    Subject: Power steering failure after two attempts at replacing the timing belt? Quote
Hello Tom!
Was die Wasserpumpe angeht kann ich die Werkstatt nicht wirklich verstehen. Wieso machen die sich die Arbeit doppelt? Wenn in meinem Betrieb (eine freie Werkstatt, nur nebenbei) ein Zahnriemen gemacht wird, der ĂŒber die Wasserpumpe lĂ€uft (egal, ob VW, Audi, Opel oder sonst was), wird diese mit ausgetauscht. Ende. Wie dein KD-Berater richtig gesagt hat kann die WaPu unter UmstĂ€nden mit der neuen Spannung nicht zurecht kommen, schlimmstenfalls endet das mit einem Motorschaden. Und diesen Schuh zieh ich mir nicht an, lieber nehm ich mir die Zeit und erklĂ€r dem Kunden die nötigen Mehrkosten. DThe extra work isn't really worth mentioning; for most cars, it takes no more than a maximum of half an hour.
Zu deinem Lenkungsproblem... das hört sich mir nach unzureichender Ölversorgung an. Beim Golf IV ist nicht nur der Keilriemen fĂŒr die Servopumpe im Weg, der ServoausgleichsbehĂ€lter muss beim Zahnriemen auch weichen. Also wĂ€ren 2 Möglichkeiten, die mir einfallen wĂŒrden. Erstens die Fuzzies haben den BehĂ€lter komplett ausgebaut und haben den Ölstand nicht richtig ergĂ€nzt (wĂ€re ziemlich sinnlose Arbeit...), sprich mal kontrollieren und gegebenenfalls ergĂ€nzen (lassen) oder, Möglichkeit zwei, sie haben den BehĂ€lter zwar drin gelassen, aber es irgendwie auf blöd geschafft die Leitungen zu verdrehen. Kontrolliere einfach mal die Leitungen, eine geht zur Pumpe runter und die andere kommt vom Lenkgetriebe hoch, ob sie evtl. sichtlich verdreht sind. Wenn yes :arrow:and then take it to the workshop and complain loudly.
What else just occurred to me... are all the fairings in the right-hand wheel well properly mounted? Is anything rubbing against either the wheel or the crankset?
Dominique.
Translated on 21-07-2026, 7:11.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
No new posts MKB Codes: Find the Right Diagnosis Code Diesel Engine Technology
No new posts MFA After Eco-Tuning On-Board Diagnostics (OBD)
