Valve Compatibility: Do Valves Fit All Rims?
dj1
Post27-09-2004, 13:49    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
I bought new rims.
Now, I also need some valves for that.
I saw that there are Raid valves that protrude only a few millimeters.
Question: Can I safely purchase these valves, or are there different sizes or types?
Best regards and thank you.
DJ.
Translated on 03-09-2026, 11:16.
Julian
Post27-09-2004, 13:59    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
Hmm, there are also cars, people, and clouds...
Could you please be more specific?
dj1
Post27-09-2004, 14:28    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
Hm, there are also cars, people, and clouds....
So, there are different types of valves, otherwise you wouldn't be asking, right?
Rims: RH-Cup (4x100 / 8.5 and 9x17 inches).
Desired valves: Auction number: 7923485349.
DJ.
Translated on 03-09-2026, 11:17.
wolfi_b
Post27-09-2004, 14:31    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
Well, I've also seen different lengths in standard valves before.
1993 Audi 80 B4 1Z
2004 Seat Leon 1M ASV
Translated on 03-09-2026, 11:18.
x world one
Post28-09-2004, 8:11    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
For example, some rims are only allowed to be used with metal valves, while with others it doesn't matter whether they are rubber or metal. As far as I know, the length of the valve doesn't play a role.
But I wouldn't worry about that. You have to get the tires mounted somewhere anyway, so just have the tire dealer do it, and optionally specify the type of valve you want (metal or chrome caps for rubber valves). icon_wink.gif
Spritmonitor
Gremlin
Post28-09-2004, 10:05    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
As far as I know, the length doesn't play a role.
Yes, it depends on the position of the valve. At high speeds, enormous centrifugal forces can be generated, which can bend a valve that is protruding too far. Over time, this will cause the rubber to break.
For motorcycle tires, the centrifugal forces at speeds above 260 km/h can even push on the valve itself. Therefore, always make sure the valve cap is securely tightened.
CU Gremlin.
Translated on 03-09-2026, 11:19.
x world one
Post28-09-2004, 10:49    Subject: Valve Compatibility: Do Valves Fit All Rims? Quote
Spritmonitor
Translated on 03-09-2026, 11:20.
No new posts Does this rim technically fit on a Golf V? Transmission, Chassis, Body & Interior
No new posts Valve Hole Diameter: Find Your Rim Size Here Transmission, Chassis, Body & Interior
No new posts Reprogramming: Custom Messages for Each Model On-Board Diagnostics (OBD)
No new posts Climatronic Compressor: Shuts Off Every 60 Seconds? Help! Transmission, Chassis, Body & Interior
