muellet2 Guest
02-10-2004, 14:16 Subject: LDA Indicator After Rainer's Tuning - Tested on 96kW TDI |
Today, I tapped into the wiring of the LD/LT sensor on my 96kW TDI.
Since I couldn't easily access the sensor's connector, I simply pierced the wires to determine which wire corresponds to which function. Here are the measurement results:
Gray/blue cable = ground.
Green/blue cable = voltage?
Cable color: yellow/black = LD Output.
Purple cable = LT Output.
'When I measure the voltage between the purple wire and ground, I get approximately 2.7V at idle. When driving in city traffic, I get around 3.3-3.5V. The voltage increases further at higher speeds.'
1. Question: Does the temperature sensor provide a linear signal?
2. Question: Which regulatory area is involved? What is the voltage at approximately 90°C LT?
When I measure the supply voltage, I get approximately 2.3V, and I was surprised that it increases and decreases during the test drive. I have installed a P-box, but the manufacturer states that it does not manipulate the boost pressure, but only increases the fuel injection amounts -> Could it still be due to the chip that this voltage changes?
When I measure the voltage between the yellow wire and ground, I get approximately 0.0-0.4V at idle. The peak voltage I observed was a maximum of 2.66V, and under full load (3rd gear + handbrake at approximately 3500/min), I measured 2.44V.
When I compare my values with Rainer's values, it becomes apparent that I most likely have a different combination sensor installed.
>> Does anyone have a datasheet for the sensor used?
Unfortunately, I've lent out my diagnostic tool at the moment, so I can't compare my values using VAG-Com.
Toby.
Translated on 15-10-2026, 10:18.
Joined: 04/12/2002 Posts: 18128 Karma: +803 / -0 Location: St.Gallen 2018 Volkswagen T6
02-10-2004, 22:33 Subject: LDA Indicator After Rainer's Tuning - Tested on 96kW TDI |
The supply voltage for the boost pressure sensor is 5V. Unfortunately, I don't have access to the characteristic curve of the temperature sensor.
Translated on 15-10-2026, 10:20.
Profile PM WWW Garage |
muellet2 Guest
07-10-2004, 17:46 Subject: Installed Wiring: How-To & Tips |
Hello again,
'The circuit is actually working in my TDI now. However, I'm using a slightly modified sensor. At idle, I'm getting approximately 2.6V instead of 2.86V. Therefore, I've divided my voltage using resistors with values of 16kΩ and 10kΩ.'
If I have a working temperature circuit tomorrow, I will post again here. I and my colleagues have already collected measurements today.
The mistake I made during my first measurement over the weekend was that I measured the voltage between the 5V line and the signal lines...
Hi and thanks again for the brilliant idea.
toby
P.S.: I measured the absolute boost pressure in the 9th measurement block under 'intake pressure.' Was that correct, or is there a separate measurement block for the actual overpressure?
Translated on 15-10-2026, 10:22.
07-10-2004, 17:50 Subject: LDA Indicator After Rainer's Tuning - Tested on 96kW TDI |
Hi Toby,
Thank you for the feedback. Could it be that you mean 1.6V or 1.82V instead of 2.xV?
Translated on 15-10-2026, 10:23.
muellet2 Guest
07-10-2004, 18:05 Subject: LDA Indicator After Rainer's Tuning - Tested on 96kW TDI |
Yes, of course, that was a little bit of a trickster  .
See you soon.
toby
Translated on 15-10-2026, 10:24.
