TDI Injector Pump Wiring Diagram
OlliP
Post06-09-2002, 9:46    Subject: TDI Injector Pump Wiring Diagram Quote
What is the difference between an 8-pin and a...?
the 10-pin pump connector.
Now, don't go saying that one has two more connections! *grin*
I would like to connect an 8-pin HOPA box to a 10-pin...
'Plug in' the fuel injection pump and ask about it!
Thank you.
Olli.
Translated on 01-09-2026, 7:11.
Post06-09-2002, 10:34    Subject: TDI Injector Pump Wiring Diagram Quote
As far as I remember, contacts 1 through 7 are assigned the same functions.
The 8-pin connector had pin 8 free. The second 3-pin connector on the "older" pump has been integrated into the 10-pin connector on the "newer" pumps.
Translated on 01-09-2026, 7:12.
Animalking
Post06-09-2002, 11:37    Subject: TDI Injector Pump Wiring Diagram Quote
Does anyone know where the pump cable is located on the 74 or 85 kW PD engines? I know these aren't VE systems, but there must be some kind of wiring that tells the engine control unit how much fuel is being injected. Sorry for the silly question, but I'm just curious! icon_cool.gif
Translated on 01-09-2026, 7:13.
No new posts Replacement of the upper seal on VP37 injection pump Troubleshooting & Guides
No new posts Injector Pump Control Unit Pinout Diesel Engine Technology
No new posts 1Z MSG connector pinout On-Board Diagnostics (OBD)
No new posts OBD2 Pinout: Connector and Wiring Explained Diesel Engine Technology
No new posts Pinout of the MFA (Golf IV) Transmission, Chassis, Body & Interior
