Spannvorrichtung für Zahnriemen beim PD | Posts 16+
Go to page: Previous  1, 2
beckertje2
Post08-01-2005, 19:11    Subject: Quote
Dirk,
Thank you for your reply. The car has been standing still for hours, and the clearance was still not back to 4 mm. Your tip about using the idle setting was helpful. After starting the engine, the clearance immediately went above 4 mm. If I have to deal with this again, the problem is that it's very difficult to access that area on a Passat. Either I would have to remove the bumper again and put the lower control arm in the service position, or 'fiddle around' and tighten the tensioner without using a torque wrench.
So, I'm going to wait and see for now.
Hardy.
Translated on 24-08-2026, 0:49.
chris11
Karma: +3 / -1   Thank you, like it!
Post09-01-2005, 14:48    Subject: Quote
ulf wrote:
However, the belt does not shorten; instead, the block grows more than the belt, which causes the tensioner to move towards its limit when the engine is hot.
Assuming a length of 400 mm for the cast iron block and 100 mm for the aluminum head, the change in length at a temperature increase of 100 degrees Celsius would be approximately 0.66 mm: (400 mm * 10.5E-6 + 100 mm * 23.8E-6) * 100. This is equivalent to a shortening of the timing belt by 1.32 mm.
More than I expected.
Christian.
Translated on 24-08-2026, 0:50.
No new posts Documentary: Transporter 7D, Timing belt failure Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing Belt Issue: A3 (98+) - Not Centered on ESP Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Timing belt snapped on the SDI! Diesel Engine Technology
No new posts Timing Belt Interval AFB/AKN Engine Diesel Engine Technology
No new posts Timing belt replaced on a 1Z engine, year of manufacture ... Diesel Engine Technology
No new posts Timing Belt 1Z Diesel Engine Technology
