Correction (oil change below)
Avenga
Post28-01-2005, 21:14    Subject: Correction (oil change below) Quote
'Since my topic below starts with phrases like 'that's probably your first...' 'Oil change' in the style of 'I'm too stupid' (the oil should be warm icon_evil.gif), it was closed, and now I have to fix it.
I've changed so much oil that I've lost count, but only on Corasas and motorcycles, never on a brand new car!
Therefore, I would rather inquire about potential faux pas.
I just did that. The only annoying part was having to screw the lower engine cover back on afterwards.
The oil drain plug didn't have a crush washer, but I got one from the rental workshop.
I also replaced the two O-rings on the oil filter cover, but I'm not sure what the purpose of the lower (smaller) one is!
By the way, the oil filter could be easily turned by hand, and it fit perfectly with the oil filter wrench! (@Jan)
I held it firmly and turned it a little further with the oil filter wrench.
It was full at 4.5 liters.
I found the passage again in the manual icon_redface.gif. It states: other engines, 4.5l diesel: 5l.
funny?
I haven't found any oil standards. Could someone perhaps find the relevant one for me and explain which one it is?
I paid: 5 liters of 5W40 oil: €17, oil filter set: €6.5, sealing ring: free icon_biggrin.gif, rental workshop: €13.5 (1 hour).
And it's NOT my car!
The oil is definitely not as black as it would be after an oil change on a Seat, but it's still somewhat yellow. It's not as light as it would be with a gasoline engine, but you can tell that it was a proper oil change.
Thank you.
Post28-01-2005, 21:18    Subject: Correction (oil change below) Quote
Have you checked the oil level, let the engine run until the oil pressure light went out, and then only filled it to the maximum level???
Otherwise, you have the maximum amount of oil in there, considering the oil filter is empty – so now there's too little in it.
Post28-01-2005, 21:47    Subject: Correction (oil change below) Quote
What's all the fuss about an oil change? My God.
Tip: Gaskets have the function of sealing.
Avenga
Post28-01-2005, 22:10    Subject: Correction (oil change below) Quote
Did you check the oil level, let the engine run until the oil pressure light went out, and then fill it up to the maximum level???
Okay, and then I drove another several kilometers, parked the car, and then checked again after 5 minutes -> exactly max.
I'm not doing this for the first time, and I know what's 'behind' it.
Post28-01-2005, 23:14    Subject: Correction (oil change below) Quote
Avenga wrote:
dieselmartin wrote:
Did you make sure to run the engine until the oil pressure light went out, and then only fill it up to the maximum level ???
I'm not doing this for the first time, and I know what's "behind" it
Okay, then I'm relieved that Jan's picture with the oil drain plug wasn't really necessary. icon_cool.gif
Avatar-Jan6K
Post29-01-2005, 0:12    Subject: Correction (oil change below) Quote
By the way, the oil filter could be loosened by hand, and it fit perfectly with the oil filter wrench! (@Jan)
Right, that was an SDI for you. Without the turbocharger boost hoses, there would definitely be plenty of space there... because on the TDI, those hoses run very close to that part.
Okay, I'm relieved that Jan's picture with the oil drain plug wasn't really necessary.
I am innocent regarding the picture with the arrow... that was Martin's fault icon_wink.gif.
Jan.
1Z5 CFHF / AHB H4D
No new posts Motorraumschutz unten, Golf 5 Transmission, Chassis, Body & Interior
No new posts Golf 5 clutch pedal stays down Transmission, Chassis, Body & Interior
No new posts Problem with AFN: Very little performance when running in... Diesel Engine Technology
No new posts Problem bei AGR Anpassung - UPDATE (unten) On-Board Diagnostics (OBD)
