VW Passat - humming noise while driving
New Topic Reply 🔗 🖨 Dieselschrauber - Index » Transmission, Chassis, Body & Interior
joergs
Post11-09-2002, 10:09    Subject: VW Passat - humming noise while driving Quote
Hello everyone,
Unfortunately, I had to make a mistake yesterday while driving my father's Passat because the exhaust pipe was rusted through again (from the inside, apparently).
During the test drive, I noticed a humming noise coming from the front axle, similar to the sound of tires with very deep treads. However, it can't be the tires, as I remember they have never made such noises before!
It could be the wheel bearings, but I'm not entirely sure. The wobble in the wheel didn't seem to have any play, and that distinctive cracking sound when accelerating or turning sharply isn't present either.
What else could it be? Could it be the joints of the constant velocity (CV) joints?
Translated on 11-07-2026, 13:29.
Post11-09-2002, 10:32    Subject: VW Passat - humming noise while driving Quote
Drive along a road with sharp curves. If the noise disappears when turning right or left, it's likely that a wheel bearing is defective.
Unfortunately, it's difficult to pinpoint the exact defective side because these are double-row angular contact ball bearings, and depending on the type of defect, they can produce noises in different load directions.
If you jack up the vehicle and manually rotate the wheel, you can usually hear which side is defective (a "chrrrr" sound when rotating).
Translated on 11-07-2026, 13:31.
joergs
Post11-09-2002, 10:41    Subject: VW Passat - humming noise while driving Quote
@rainer
Okay, I'll give it a try!
@everyone
If it turns out that the front wheel bearings are the problem: how do you replace them? Is a press really necessary to install and remove them?
Translated on 11-07-2026, 13:32.
Post11-09-2002, 11:02    Subject: VW Passat - humming noise while driving Quote
Hello.
joergs wrote:
@all
fall es doch die vorderen radlager sind: wie wechseln ? braucht man wirklich eine presse zum ein-/auspressen ?
No, a heavy-duty vise and at least a 2 kg hammer are also sufficient. icon_biggrin.gif
Translated on 11-07-2026, 13:33.
Arne
Post13-09-2002, 17:23    Subject: VW Passat - humming noise while driving Quote
If it's not the wheel bearing, you might want to take a look at this post. It was similar to what you're experiencing. It drove me crazy icon_smile.gif.
Other possible causes could have been:
icon_arrow.gif Mounting the power steering pump?
icon_arrow.gif Shock absorbers?
icon_arrow.gif Generally, exhaust system design.
It turned out to be a screw from the engine mount in my case. I was so relieved when it was finally fixed.
Nice weekend icon_cool.gif.
Arne.
Translated on 11-07-2026, 13:34.
Jonny1303
Post18-09-2002, 13:32    Subject: ... it could also be the tires Quote
Hello DirkS,
Possibly, a saw-tooth pattern has formed specifically on the front tire, which could be causing that humming noise during driving.
Unfortunately, the saw-tooth pattern is often just a symptom; the underlying cause is usually faulty shock absorbers.
Just run your hand across the tires, in the direction opposite to the way the vehicle is moving.
Jürgen.
Translated on 11-07-2026, 13:36.
No new posts TDI Synchronization Angle: What is it? Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts WIV reset on VW Polo 9N TDI Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts bora TDI engine stalls while driving On-Board Diagnostics (OBD)
No new posts Problem mit meinem A6 Avant TDI beim rauf fahren. Upload
No new posts mit heizöl fahren...funktioniert das?? Diesel Engine Technology
No new posts 1.8T engine with high mileage, what oil should I use? Gasoline Engine Technology
