Airbag Error 00532: Control Unit Troubleshooting
New Topic Reply 🔗 🖨 Dieselschrauber - Index » On-Board Diagnostics (OBD)
x world one
Post26-06-2005, 19:49    Subject: Airbag Error 00532: Control Unit Troubleshooting Quote
"Today, during a check and various maintenance work, I read the following error code in the airbag control unit:"
00532 - Supply Voltage B+
07-10 - Signal too low - Intermittent.
Control unit information:
Control Module Part Number: 6N0 909 603 E
Component and/or Version: AIRBAG VW2 V00
Software Coding: 00069
Could this error possibly be related to the battery replacement that took place earlier this year?
The old battery just gave out.
After deleting the error code, turning off the ignition, turning it back on, and taking a test drive, the error did not reappear.
Thank you.
Spritmonitor
Translated on 04-08-2026, 17:45.
vagtuning
Post26-06-2005, 20:18    Subject: Airbag Error 00532: Control Unit Troubleshooting Quote
I would say: Yes.
Translated on 04-08-2026, 17:47.
hb2000
Post27-06-2005, 11:38    Subject: Airbag Error 00532: Control Unit Troubleshooting Quote
Normally, errors will disappear from the control units after a few restarts. However, with the airbag control unit, they tend to persist because it is a critical control unit. The error is definitely caused by the weak battery and the subsequent replacement at the beginning of the year. Did the warning light actually come on, or did you only discover the error when accidentally reading out the control unit?
x world one
Post27-06-2005, 12:41    Subject: Airbag Error 00532: Control Unit Troubleshooting Quote
I only found the error when reading the diagnostic data. I don't recall any persistent airbag warning lights, although they are essentially pointless on the Golf 3 anyway...
Spritmonitor
Translated on 04-08-2026, 17:48.
hb2000
Post27-06-2005, 12:48    Subject: Airbag Error 00532: Control Unit Troubleshooting Quote
Then the airbags should still function even if the light isn't illuminated. I wouldn't worry about the error anymore, as it was clearly caused by the low battery voltage at the beginning of the year.
x world one
Post27-06-2005, 14:43    Subject: Airbag Error 00532: Control Unit Troubleshooting Quote
Then I'm relieved, the vehicle is currently being prepared for the summer vacation. icon_cool.gif
Spritmonitor
Translated on 04-08-2026, 17:49.
No new posts Doku A3 8L, Fehler 65535 im Airbag STG Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Doku A3 8L, Fehler 65535 im Airbag STG, bis 8LYA078299 Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error Zünder 1 for Airbag (Passenger Side) - N131 Resistor Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Error 00532 - Power supply / Short circuit after positive... Diesel Engine Technology
No new posts Airbag Fehler On-Board Diagnostics (OBD)
No new posts A3 TDI: Fehler 65535 im Airbag-Steuergerät On-Board Diagnostics (OBD)
No new posts GRA Supplemental Restraint System (SRS) Installation Erro... On-Board Diagnostics (OBD)
