Interior Monitoring Audi A6 C5: Installation & Wiring
christians
Post18-09-2005, 20:20    Subject: Interior Monitoring Audi A6 C5: Installation & Wiring Quote
I'm currently installing a parking heater in my Audi A6 from 1999, but I'm having trouble with the wiring for the interior monitoring system. I have a limited instruction manual from Webasto (for models from 1998 onwards) and a generally better one from Audi (for A6 models after the facelift), but I can't find the connectors and pins that are mentioned there (and which differ!). There seems to be only a coupling station on the right B-pillar, not the control unit.
Can anyone help me with information related to my year of construction? Erwin is asking for 107 euros...
Gruß Christian
Translated on 05-08-2026, 3:55.
Post19-09-2005, 19:06    Subject: Interior Monitoring Audi A6 C5: Installation & Wiring Quote
You have email...
Translated on 05-08-2026, 3:56.
christians
Post20-09-2005, 20:44    Subject: Interior Monitoring Audi A6 C5: Installation & Wiring Quote
It helped me.
From the control unit located between the left rear seat belt and the airbag, contact pins 4 and 14 (which are the same) connect to a two-pin (4mm) connector on the A-pillar coupling station. The colors are as follows: pin 14 is black/green, and pin 4 is brown/green.
Thank you again!
Gruß Christian
No new posts Comfort Control Unit Without Interior Monitoring On-Board Diagnostics (OBD)
No new posts Interior Monitoring Sensitivity in G4 Variant Transmission, Chassis, Body & Interior
No new posts KGE Installation Location at AKN Diesel Engine Technology
No new posts Engine Control Unit (ECU) Location On-Board Diagnostics (OBD)
