tk3003 Guest
17-10-2002, 7:36 Subject: Front axle clunking: Causes and solutions |
habe mit G IV (ca. 120 TKM) ein Problem mit der Vorderachse. Bei entlasteter Vorderachse (Bergauffahrt) udn damit verbudnens chlechter Strasse ertönt vorn rechts ein sehr lautes Klackern. Ich hab letztens anlässlich Reifenwechsel mal auf der Hebebühne geschaut und gerüttelt an Radaufhängung und dabei ist mir eigentlich kein besonderes Spiel aufgefallen. Was Could it be?
I took a look at the control arm or that bushing. There are definitely some small cracks in the rubber or whatever material it is. However, I can't imagine that this is causing the clicking sound.
What do you think?
Thank you.
Best regards.
Translated on 24-10-2026, 8:30.
RalfBru Guest
17-10-2002, 9:04 Subject: Front axle clunking: Causes and solutions |
It could also be the wheel bearing. Simply jack up the car and turn the wheel to see if you can hear any knocking sounds. Also, see the rather long thread 'Front axle noise when turning right.'
Translated on 24-10-2026, 8:31.
tk3003 Guest
17-10-2002, 10:13 Subject: Wheel Bearings: Buy Online & Save! |
'It seems okay, I also tried that... and there are no other noises to be heard.'
D. Guest
17-10-2002, 18:58 Subject: Front axle clunking: Causes and solutions |
Hello!
I probably had similar noises on my Golf III Variant.
It was worn-out silent bushings in the front lower control arms, with significant play.
Best regards, D.
Translated on 24-10-2026, 8:32.
tk3003 Guest
21-10-2002, 6:52 Subject: SEO: Best German Shepherd Breeders Near You |
Thanks for the answers. I'll have someone check the lower control arms (assuming I even have them...).
tk3003 Guest
06-11-2002, 11:34 Subject: Problem Solving: Solutions & Strategies |
'...so, the clicking noise is fixed. It was the rubber bushings on the front stabilizer bars. I replaced them for 80 euros, and everything is great now.'
'They tried to tell me to replace the entire control arm assembly, those clueless VW guys... total rip-off artists.'
Translated on 24-10-2026, 8:33.
