Extend 5th Gear: How To & Benefits
Boro
Post13-02-2006, 10:17    Subject: Extend 5th Gear: How To & Benefits Quote
I would like to ask another question regarding the extension of the 5th gear in a CYP gearbox!
The following part numbers appear in the previous threads:
02A 311 361 AM; 02A 311 158 AF = 28/40 = 0.7
02D 311 361; 02D 311 158 = 32/47 = 0.681
The earlier ones should be the original gears from the ASD transmission, while the later ones are from the T4 Syncro transmission. Now, I specifically want to install the combination from the T4 and I'm wondering if anyone here in the forum has already done this. Do the gears fit properly with the 02A CYP transmission? In other forums, you often read that the needle bearing needs to be replaced.
Here's a page with pictures of the renovation for anyone interested.
http://www.wiesestefan.de/
Translated on 30-08-2026, 5:20.
Boro
Post15-02-2006, 13:01    Subject: Extend 5th Gear: How To & Benefits Quote
Habs selbst herausgefunden! It fits!
Here's another interesting thread on the topic.
http://forum.fueldner.net/viewtopic.php?t=285&postdays=0&postorder=asc&start=0
Translated on 30-08-2026, 5:21.
cksIT
Post16-02-2006, 10:11    Subject: Extend 5th Gear: How To & Benefits Quote
Why the T4 Syncro?
It should probably have a smaller engine, since it already reaches its top speed of 160 km/h.
or have I missed something again?
Is it the same as it appears in the pictures on the T4 model?
I was planning to do that soon. Can anyone tell me what other tools I might need?
Should we replace anything else?
I have an impact wrench.
By the way, has anyone ever replaced the release bearing?
My uncle said that it can be done from the outside, but in the AKTE catalog, I found it on the inside of the transmission.
Translated on 30-08-2026, 5:22.
Post16-02-2006, 11:34    Subject: Extend 5th Gear: How To & Benefits Quote
In addition to the gears, there's also the axle ratio to consider.
And that will be quite short for the T4, accordingly icon_smile.gif.
"Which gearbox did your uncle replace the A-bearing on?"
For Golf 2 and smaller G3 gasoline engines (with the 020 transmission), the clutch disc pressure plate is located on the outside, as the pressure plate sits at the very edge and presses against the clutch via the hollow-bored transmission main shaft.
This shaft-in-tube assembly tends to rattle, especially when you're stopped at a traffic light with the clutch disengaged.
To my knowledge, on the G3 GTI 16V, VR6, and TDI models (with the 02A transmission), it is NOT possible to replace the clutch release bearing from the outside, as the bearing is located INSIDE the transmission bell housing.
Translated on 30-08-2026, 5:24.
cksIT
Post16-02-2006, 17:43    Subject: Extend 5th Gear: How To & Benefits Quote
ok,
He did that during the two-person scramble.
I already suspected that, so the entire transmission needs to be removed before changing it... :/
Translated on 30-08-2026, 5:25.
Boro
Post20-02-2006, 10:48    Subject: Extend 5th Gear: How To & Benefits Quote
Can someone tell me which gearbox these gears with the following numbers are from?
02A 311 361 AM, 02A 311 158 AF.
'Where did they come from?! They definitely don't come from ASD!'
cksIT
Post21-02-2006, 7:46    Subject: Extend 5th Gear: How To & Benefits Quote
grj
hnv
ewt
ggu
ewb
I'm sorry, I can't translate that. It appears to be a single word with no context. Please provide a complete sentence or paragraph for me to translate.
These gears were installed in vehicles such as the A2 Polo, Passat, Transporter, and Golf Plus.
Translated on 30-08-2026, 5:26.
cksIT
Post21-02-2006, 9:43    Subject: Extend 5th Gear: How To & Benefits Quote
Just wondering, which gear can I use in an Audi A4 AFN (same as Passat 3B)?
The engine is mounted longitudinally.
Translated on 30-08-2026, 5:27.
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Documented noises from the dual-clutch transmission, 6-sp... Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Gear Noise, 6-Speed Transmission Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts A3 8L: Extend 5th Gear (AHF/EBF) Diesel Engine Technology
No new posts Extend Hallways? Tips & Ideas. Diesel Engine Technology
No new posts Gear Ratio Increase for Audi A4 Diesel Engine Technology
No new posts Extend Antenna Cable: How-To Guide Transmission, Chassis, Body & Interior
