Extend Gear Ratio: How To & Benefits
cksIT
Post26-04-2006, 12:47    Subject: Extend Gear Ratio: How To & Benefits Quote
I bought an A4 1.9 TDI with 110 horsepower, and unfortunately, it has such short gearing that I can already reach its top speed at 100 km/h.
"According to Elsawin, the translation in position 5 for me is 28:41 = 0.683 (APL)."
There probably isn't anything bigger, right?
Can the axle ratio be changed, or is that not possible?
"It's really frustrating because I often use the train, and right now I'm constantly stuck around 4000 RPM. If I even reach 210 km/h according to the GPS, I'm already in the red zone!"
A 6-speed gearbox isn't exactly cheap... Would the one from a 2.5 TDI fit?
Translated on 06-09-2026, 20:56.
Post26-04-2006, 13:28    Subject: Extend Gear Ratio: How To & Benefits Quote
Hi.
Could you possibly get more performance by using larger tires?
On the G3 Var, the transmission is also shorter than on the standard G3, but it has larger tires to compensate: 195/60 14 instead of 185/60 14, which is 2% larger.
Translated on 06-09-2026, 20:58.
Udo
Post26-04-2006, 16:46    Subject: Extend Gear Ratio: How To & Benefits Quote
Look at this: https://community.dieselschrauber.org/en/viewtopic.php?t=448
I had slightly larger tires registered for my vehicle.
Udo.
cksIT
Post26-04-2006, 22:00    Subject: Extend Gear Ratio: How To & Benefits Quote
"That doesn't really achieve much... It would only be worthwhile if you put on 18-inch tires, then you would at least have some actual tire tread."
but on the transmission itself??
It's really easy to do on the G3.
Translated on 06-09-2026, 20:59.
No new posts Subject: Extending Diesel Filter Replacement Interval Troubleshooting & Guides
No new posts Extend Hallways? Tips & Ideas. Diesel Engine Technology
No new posts Extend 5th Gear: How To & Benefits Diesel Engine Technology
No new posts Gear Ratio Increase for Audi A4 Diesel Engine Technology
No new posts Extend Antenna Cable: How-To Guide Transmission, Chassis, Body & Interior
