Engine Failure: Causes of Coolant Starvation
JanB
Post25-11-2002, 16:24    Subject: Engine Failure: Causes of Coolant Starvation Quote
'Hey, a friend's Passat with the AFN engine experienced a piston seizure due to a loss of coolant, which isn't uncommon. However, the temperature gauge hadn't moved from the 90° mark beforehand, and the warning light hadn't even blinked (model year 1998, with the blue instrumentation).'
Now I've also noticed that the temperature gauge consistently seems to stick at 90°C after about 5 minutes of driving, ever since VW introduced the electronic speedometers (I believe starting with the '96 model).
It is said that the customer should not be disturbed by fluctuations in the advertising needle.
to be worried...
Has anyone ever seen a temperature reading that was completely off the charts?
'Had it been raised higher, and could there have been similar consequences? How can one protect themselves in the future, especially during highway driving?'
Best, Jan.
Translated on 26-10-2026, 10:33.
zzzZZ
Post25-11-2002, 16:29    Subject: Engine Failure: Causes of Coolant Starvation Quote
'Mine doesn't go above that specified mark (G3 AFN 10/96) either, but it takes me considerably longer than 5 minutes to reach that point.'
After replacing the water pump, at least the warning light came on during the drive home from the mechanic's shop - because not enough water was added icon_mad.gif. However, the gauge still didn't move!
René K.
Translated on 26-10-2026, 10:34.
Passi_Fire
Post25-11-2002, 20:09    Subject: Engine Failure: Causes of Coolant Starvation Quote
'What about the water pump? I also have one lying around that I've been meaning to install for a long time. How is the wear and tear on the pump? My car has 250,000 km on it. Would it be time to replace it? Also, my temperature gauge has been creeping up from 90 to 95 degrees Celsius over the past half year, and I've experienced the same thing you described: the gauge used to be stuck at 90 degrees, and now it's always stuck at 95 degrees. Could this be related to the pump? Would it be a good idea to replace it? Let me know, thanks. - Chris'
p.s. The vehicle is a Passat Limousine with an AFN engine and 110 horsepower.
Translated on 26-10-2026, 10:36.
christians
Post25-11-2002, 20:46    Subject: Engine Failure: Causes of Coolant Starvation Quote
The pump's performance remains unchanged - until its demise.
A failure can manifest as a leak, or simultaneously, the bearing of the shaft may be worn out. This can lead to such a sudden loss of water that it may not be detected early enough, for example, on the track, and the engine may suffer a catastrophic failure due to overheating.
Only the temperature sensor in the surge tank can prevent this. The temperature display is too slow to react.
I also read that a pump failure can cause the timing belt to slip, which can also have fatal consequences.
In this thread, it was also suggested to proactively replace it. Conveniently, during the next timing belt change. Which, unfortunately, happens more often than one would like :-(.
Christian.
Translated on 26-10-2026, 10:37.
Markus H.
Post25-11-2002, 22:57    Subject: Warning Light: Meaning & Troubleshooting Quote
Ideally, a sensor should be installed in the expansion tank that activates the coolant warning light in case of a loss of coolant.
Even my old AAT (5-cylinder) has done that before (I needed it recently when an Audi mechanic forgot a gasket after replacing the thermostat - by the way, the temperature also didn't rise in that case)!
Since the AFN engine mentioned is a relatively new model, it probably has that feature as well, right?
If the lamp didn't turn on, it could only mean that either the lamp itself or the sensor was faulty, which is obviously a critical issue.
Translated on 26-10-2026, 10:39.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
No new posts MFA After Eco-Tuning On-Board Diagnostics (OBD)
No new posts WFS after engine conversion On-Board Diagnostics (OBD)
