Looking for Sachs sport clutch reviews
pa-mm6
Karma: +1 / -1   Thank you, like it!
Post04-12-2006, 23:23    Subject: Looking for Sachs sport clutch reviews Quote
Hello.
"I drive a Golf 4 TDI 4Motion ARL with a chip tuning. It seems like my clutch is about to fail soon. I'm planning to install a Sachs performance clutch when my old one gives out. Has anyone else done this before?" Is there a big difference?
What are some recommended upgrades or modifications for a Volkswagen Golf 4? The vehicle should remain roadworthy.
Sure, here's the translation:
"MFG" is an abbreviation for "Mit freundlichen Grüßen," which translates to "Sincerely" or "Best regards" in English.
Audi SQ5 8R Cvub
Back to top Profile PM Email
Aron
Karma: +5 / -1   Thank you, like it!
Post04-12-2006, 23:30    Subject: Subject: Looking for reviews of Sachs Sport clutch Quote
pa-mm6 wrote:
Hello.
MFG
Hi...
I had another one refurbished once, but I haven't installed it yet because it belongs to a different gearbox.
We also did the same for a customer's 206 RC (2.0 gasoline engine, 180 hp). We had organic pads, model B6088, installed. In his case, the pads cut off the power flow with a noticeable jerk at high engine speed differences, but the automatic transmission was also reinforced by 20%. In most diesel clutches, it is unfortunately not possible to reinforce the automatic transmission, but only the friction material icon_twisted.gif.
When starting, you need to be very delicate with the clutch, but it's manageable. However, with the sintered metal parts, you lose the ability to fine-tune the engagement.
Did the company Hennig Fahrzeugtechnik in Essen manufacture the extreme equipment for Sachs?
donalexo
Post05-12-2006, 8:21    Subject: Looking for Sachs sport clutch reviews Quote
Hello pa-mm6!
I have a Sachs Racing clutch installed in my Audi A3. It's a clutch with a torsionally sprung disc and organic friction linings. In your case (ZMS), you would need to use a rigid disc with organic friction linings.
Basically, the clutch is good, very well controllable, although it requires significantly more force and has a much shorter range of modulation!!!
My wife has hardly driven the car since the modification, because she says she gets cramps in her thighs after 5-10 minutes of city driving icon_wink.gif.
Well, I don't find the clutch to be that difficult to operate, but it does require some getting used to. You experience a noticeable reduction in comfort, but the clutch is really excellent and provides a good amount of torque.
Initially, I noticed a slight tendency for the engine to stall, but this was resolved by engaging the clutch.
Alex.
Touran 1.9 TDI, EZ 09/2004
Tagessuppe
Karma: +36 / -0   Thank you, like it!
2001 Audi A2 Consumption
Post05-12-2006, 13:44    Subject: Looking for Sachs sport clutch reviews Quote
I installed a Sachs Performance clutch about 40,000 km ago, after the old one slipped due to the chip. The price, performance, and build quality are simply excellent. For me, the modulation path remained the same, and the amount of effort required was actually reduced.
The driving comfort remained, but the clutch still engages very abruptly. No slippage, even when engaging under load.
pa-mm6
Post05-12-2006, 17:09    Subject: Looking for Sachs sport clutch reviews Quote
Tagessuppe wrote:
I installed a Sachs Performance clutch about 40,000 km ago, after the old one slipped due to the chip. The price/performance ratio and build quality are simply excellent. For me, the modulation path remained the same, and the amount of effort required was actually reduced.
Hello.
Thank you for your feedback. What exact model of car do you have?
Audi SQ5 8R Cvub
Arne
Post05-12-2006, 17:31    Subject: Looking for Sachs sport clutch reviews Quote
My landlord also has the Sachs Performance clutch, and there's no difference compared to before. Leon ARL with chip.
Arne.
pa-mm6
Post05-12-2006, 17:33    Subject: Looking for Sachs sport clutch reviews Quote
How come it's not performing better? Or, is there anything else that can be done? Supposedly, it's supposed to handle up to 440 Nm on a Golf 4 without any problems.
Does anyone happen to know where I can get these at the best price?
Audi SQ5 8R Cvub
Aron
Post05-12-2006, 18:23    Subject: Looking for Sachs sport clutch reviews Quote
pa-mm6 wrote:
how can it not perform better? Or, is there anything else going on? Supposedly, it's supposed to withstand up to 440 Nm on a Golf 4 without any problems.
MFG
You have to be careful which ones you get; in my case, the Sachs Performance ones had the standard Sachs part number, so I would only consider having a new friction disc riveted onto the old pressure plate. Or explicitly, something with an organic coating.
If the clutch pedal becomes easier to press after a while, it usually indicates a new automatic transmission. Over time, it will gradually become a bit harder to press again. In the case of the gasoline engine, we had the automatic transmission reinforced (with 20% stronger springs), and the difference is very noticeable.
Tagessuppe
Post06-12-2006, 10:44    Subject: Looking for Sachs sport clutch reviews Quote
Hi!
I have an Audi A3 with 90 horsepower, which now has 135 horsepower thanks to a chip tuning and larger injectors.
I got my clutch from this company: [email protected]
320,- including shipping to Austria. The set included a friction plate, pressure plate, and release bearing. The 440 Nm figure seems realistic to me.
pa-mm6
Post06-12-2006, 17:02    Subject: Looking for Sachs sport clutch reviews Quote
Tagessuppe wrote:
Hi!
320,- including shipping to Austria. The set included a friction plate, pressure plate, and release bearing. The 440 Nm seem realistic to me.
Hello.
Is that then the Sachs Performance version? I currently have a few offers, but none of them are below 600€.
Audi SQ5 8R Cvub
Tagessuppe
Post06-12-2006, 17:24    Subject: Looking for Sachs sport clutch reviews Quote
Yes, it's Sachs' performance.
However, my Stone Age AGR (automatic gearbox) with a wastegate turbocharger has a "normal" clutch.
It will likely be more expensive with a dual-mass flywheel.
No new posts Looking for reviews of Zimmermann brake discs Transmission, Chassis, Body & Interior
No new posts MSG Alternatives: Reviews & Experiences On-Board Diagnostics (OBD)
No new posts Welche Sachs Kupplung für AFN (ZMS) Transmission, Chassis, Body & Interior
No new posts Sachs Valeo Clutch Upload
