Troubleshooting after error code reading
Mike²
Post27-12-2006, 22:36    Subject: Troubleshooting after error code reading Quote
After experiencing problems with the orange warning light on my Polo (9N, 1.9L, manufactured in 2004) – the same light that comes on when the ESP is deactivated –
I performed a diagnostic scan on a friend's car.
Even though it can't perform a fault-guided diagnosis, we still aren't making any progress.
Here's the translation:
"The following are the errors or error codes:"
1.)
01 - Motor electronics.
038906019LA
1.9L R4 EDC G000SG 5405
Error:
17911
Belastungssignal von Generatorkl. DF
sporadically
2.)
03 - Brake electronics.
6Q0907379Q
ESP 5.7 font, H03.
Error:
18265
Last signal.
sporadically
3.)
08 - Climate control/heating electronics.
6Q0907044B
CLIMAtronic PQ24
Error:
00710
Defrost flap actuator - V107.
sporadically
Error:
01273
Fresh air blower - Version 2.
sporadically
I assume that all four errors originate from the same source.
Can someone provide me with more details about this information?
Or do you require any further information?
Thank you in advance.
Mike squared.
Translated on 23-09-2026, 19:49.
Post28-12-2006, 0:16    Subject: Troubleshooting after error reading Quote
The MKB wouldn't be bad...
but the search function excludes the thread https://community.dieselschrauber.org/en/viewtopic.php?t=1793&highlight=17911.
The error code 17911 is also mentioned there.
Error code: 17911.
Load signal from generator terminal DF: implausible signal.
Possible causes:
Generator failure.
Voltage regulator faulty.
Power outage.
Possible effects:
Auxiliary heating not working.
So, if your on-board voltage is incorrect due to a defect (see above), then the other errors are likely secondary issues resulting from that initial problem.
Translated on 23-09-2026, 19:52.
No new posts Audi A4 B7/8E 1.8T BFB - Shaking/Vibration after cold start Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document: Performance loss over time, MKB AFB, AKN, AKE, AYM Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Document A3, Differential Failure After Mileage Faults & Documentation (Audi, VW, Seat/Cupra, Skoda)
No new posts Car pulls right after tire change Transmission, Chassis, Body & Interior
No new posts Increased fuel consumption after MFA following AGR decomm... Diesel Engine Technology
No new posts MFA After Eco-Tuning On-Board Diagnostics (OBD)
This topic is locked, you cannot edit or reply. Regeneration nach km Diesel Engine Technology
